Please help me with this sound...possible belt issue
SunLitSandMax00SE
Car: Silver 2006 Infiniti M35
Woke up this morning to hear this lovely sound. Seems like it's one of the belts, but I am not sure which one. I did change one of the belts a few summers ago so I am not sure if it would go bad that fast. Any ideas and if it is one of the belts, is it ok to drive on at least until I can get it fixed? Thanks.
bbs350z
Car: 350z built tt
350z st track whore
m35x daily
evo 8- 30r sold
holy s*** that sounds horrible. does it increase with revs??
SunLitSandMax00SE
bbs350z wrote:holy s*** that sounds horrible. does it increase with revs??
Yep :(
myother45isalesbaer
Car: 2004 M45 Q70 awd,4.5
Sounds horrible to me too. I am guessing, but that sounds internal and not a belt. The off beat sound is throwing me off. If it increases with revs it could be a belt , but it sounds like a cylinder missing due to a valve problem. Is it firing on all cylinders or is it missing? Without actually hearing and driving it the first thing I would do is check your oil level and make sure it is full. Could be a ton of different things. Take it to a mechanic and don't drive it with that sound.
zerg711
OMG, that's a terrible sound! I've never heard belts sound like that. I also think it's an internal issue.... Wow... Good luck, man!
Fezzik
Car: 2010 G37 Vert w/ stage 1 GTM supercharger
WOW. I've messed with the vq35 engines for along time and heard a lot of things, but not this. Like others have said it sounds internal like maybe a valve. I've seen one instance where the car made this noise and that's when a screw from the butterfly of the throttle body came off and went into the engine. but that was on a 5th gen maxima with the vq engine
lovemycarM35
Car: 2014 Lexus GS 350
With F-Sport Package
Nebula Gray
19" wheels
12.3 inch display
Navigation
Drive belt tenser maybe I'm tring to find the sound dlip the user posted
CPJ LB
Car: 12 G37X Sedan- stealthy modded
14 Altima 2.5
08 Tahoe
06 M35 S (gone)
14 Versa 4dr (gone)
by chance how was the car driving prior to you hearing the noise??
prolly low or no oil which may have caused excessive internal damage...tow it to a mechanic.
good luck bro!!
SunLitSandMax00SE
CPJ LB wrote:by chance how was the car driving prior to you hearing the noise??
good luck bro!!
It's been driving fine. I know I am way over due for an oil change and when I check the oil last night, it was at the end of the lowest marker. Dumb on my part to not have gotten it changed.
GQM45s
Car: 2008 Infiniti M45 Sport Tech Pkg, Advance Tech Pkg, Mobile Entertainment Pkg
You think it maybe a sparkplug misfiring? Or a cylinder problem. I dont think a belt would do any problems like that
SunLitSandMax00SE
I am not sure, I have never heard anything like this before. I guess I will be looking to get it towed as soon as I can.
Fezzik
Try taking the cover off and see if you can isolate the noise better.
Fezzik
I asked a good friend of mine who is an infiniti service manager and this is what he msged to me
"i would rec to first add oil!! these dipsticks are hard to read and people often mis read them. if the noise still does not go away, take the belts off and start engine to see if a tensioner is bad or idler pulley. if the noise is still there, possible timing chain noise, maybe one of the plastic guides wore off and chain is slapping, is there a cel, running rough?"
SunLitSandMax00SE
Fezzik wrote:I asked a good friend of mine who is an infiniti service manager and this is what he msged to me
Will add some oil tomorrow and let it run for a bit to see if it goes away. If that doesn't work, i'll be having it towed to the shop if I can't see anything from the surface wrong. I don't have a garage at my disposal to work in which sucks and with work and temps around 30 degrees here, there won't be much work done by myself on it.
GQM45s
hope it works out for you, keeps us posted
lovemycarM35
Nebula Gray
19" wheels
12.3 inch display
Navigation
good luck bro!!
Well thats why your motor sound like that :facepalm: the dealer may void your warrenty
SunLitSandMax00SE
Got to the shop and it was......a bad belt lol. The AC belt had split in half, half away around the circumference of the belt which was the sound in the video (the split part was off the pulley hitting things). All new belts, oil change and $260 later, the M is running like a champ. Thanks guys for all your help
Partysan7
Car: 2008 M35
SunLitSandMax00SE wrote:Got to the shop and it was......a bad belt lol. The AC belt had split in half, half away around the circumference of the belt which was the sound in the video (the split part was off the pulley hitting things). All new belts, oil change and $260 later, the M is running like a champ. Thanks guys for all your help
Hey,,, thats good to hear I had a similar problem with noise , the only difference was that for me it was happening only when slightly touching gas pedal and revving at 800 - 1200 rmps only with warmed engine...
Your sounded louder than mine but still it can get frustrating not knowing what it can be. Noise is a bi*ch & travels everywhere. My problem was isolated by replacing belt tensioner.
bbs350z
Car: 350z built tt
350z st track whore
m35x daily
evo 8- 30r sold
whew, good to hear
