Please help me! Ichiba 5 lug swap issues. s13. can't get old hub off!
240sxDann
Car: 1993 240sx Coupe
Ok so I really need some help. I have ichiba 5 lug hubs. I'm working on the rear right now. Its an s13. I can NOT get the old hub off. I took off all the brake stuff, took off the axle nut, took out the 4 bolts on the back, and it will NOT budge, at all, period. It must be so effin rusted on there I dont even know what to do. I pulled on it, pried on it, everything. I soaked it in wd40 when I was done messing with it tonight to let it sit overnight. Is there something I'm missing? Or is it just rusted solid? The only thing thats holding it on is the axle nut and the 4 bolts right? I tried for hours to get it out, and not even the slightest little movement. PLEASE HELP! I'd say get a BFH but I dont wanna mess anything up...
boro drift
Car: '87 Supra, '92 240 with SR20 and '98 12 valve Cummins
You may require a puller. Or, pry on the hub and hit the end of the axle with a SOFT hammer.
ny240gtr
Car: 1992 240sx coupe
i had the same problem i had to hammer the s### out it get a big hammer and a strong flat head screw driver and hit it were the hub seats on the assembly and use a lot of wd40
maximaRIP
Car: maximaRIP 240sx 1976 chevy van
you can also use a blow torch and heat up the hub really good then hammer it out that always those for me,when im taking out axle or bolt off the heat make the hub expand..
smocan
Looks like your going into the axle housing....
If it doesn't come off, your gonna need to disconnect all your suspension links and crack open the axle housing to get it out. Sometimes the wheel bearing can get seated inside pretty good.
Good luck, its a pain in the ***.
ilovesideways
Car: 240SX S-13 KA24E
drill a hole in it run a bolt in and then use a puller on it. Should pop right off.
240sxDann
thanks guys I appreciate it! I actually got a air hammer in between them and popped them off. SO...I got them off, got the new ones all, and realize both back calipers are seized. SUNUFFABICHHHHHHHHHH!!!!!!! lol AND! that the 5 lug lexus wheels I have, the center hole isn't big enough to fit over the center of the hub lol. So now I gotta get new rear calipers (or rebuild them) and figure out a way to open up the holes in the wheels. one problem after another lol. Good news though, whole it was all apart I got my coilovers on!
ilovesideways
make the hole in the center of the wheel bigger? Sounds
240sxDann
lexus wheels. hub bore is about 1.5mm too small.
ilovesideways
how do you plan on shaving those badboys out?
sldewyz
Car: 97' Danger Ranger
ilovesideways wrote:how do you plan on shaving those badboys out?
dremmel ftw!!! or possibly a hole saw??? thats what id do, or sell those bad boys and find some other wheels that fit
splintercell
Car: 1989 Nissan 240sx HB CA18DET
1991 Nissan Silvia Q's SR20DE ITB's
^WOW I wouldnt recommend that all. please take these to a machine shop and have them do it. it would be more precise than a dremel. a hole saw wont do it because the hole is already there. thats kind of what the arbor is for in the middle.
AZ89two4Tsx
sldewyz wrote:dremmel ftw!!! or possibly a hole saw??? thats what id do, or sell those bad boys and find some other wheels that fit
Please don't ever do that.
240sxDann
ok, I realized I'm actually just retarded. With the spacers, the wheels dont even touch the center of the hub! yay
gold on gold yo
Car: '95 Nissan S14 SE
pics!!!!!!
240sxDann
this is just a "mock up" of how they will sit. Studs are too short. Lugs have like 1 thread holding the wheels on lol.
