not to that extreem but it will cause some piston slap and if you not leaving her stock and planning to get some power out of her, do it right..for a few bucks you can get a set of pistons and bore the block out..compactfean wrote:If you put that motor back together like that, the piston will scuff the cylinder walls and yes..... Make you loose performance due to the rings not being able to seat properly.... Better yet, possibly cause the piston to jackknife in the cylinder destroying the block. Choice is yours.
