pics of my dropped cube
Home of the Nissan Cube forum and CubeDriver.com
501
havent posted these up yet...enjoy :biggrin:
then when i first walked up to it :woot:
front wheel fitment
rear wheel fitment(rubbing...lol) camber is -3 in this pic current has no rubbing at about -4
wheel specs are
rear 16x8 +0
front 16x7 +15
Repo Man
Car: 2020 Frontier Pro4X
2003 Honda Accord
Freaking awesome. I love it! :dblthumb:
How are you adjusting camber?
chompsticks
Car: ???? Nissan Cube Krom
You said being that low you have CV binding at low speeds?
501
chompsticks wrote:You said being that low you have CV binding at low speeds?
yes it causes just little shimmy under acceleration between 10-20mph itermittenly...doesnt happen all the time, just certain combos like turning and ccelerating
also had my alingment checked today :rotflmao
frt camber -5/16
rear camber -7
rear toe in 1"3/16ths
thrust is -5/16ths
going this low and agressive is not for the faint of heart
i think i may get 5k miles out of my tires :lolling:
501
AZhitman wrote:How are you adjusting camber?
me and a couple others are using camber shims from Dan at realcamber.com
and i am still working on fitment and experimental camber stuff ;)
501
Repo Man wrote:Freaking awesome. I love it! :dblthumb:
thanks!! i love it too
Zero2Endless
Car: 2002 VW GTI 337 (Sold) 2009 Pearl White Cube 1.8S 6MT
YEAHHHHH. DOPE AS FUDGE.
Now I REALLY want coil overs...I'm assuming that's what you have bolted-on LoL.
chompsticks
Hmmm... Just wondering and not trying to get into a huge debate about this, but... Can cv binding lead to premature wear on the cv joints?
I really want to go lower and am thinking about getting some Ksports and installing the fronts to get that extra half inch.
What is your ride height again from ground to fender?
501
yes it can cause premature wear...my thoughts not enough for them just to go boom...
i am at 23" ground to fender up front.
i will probably raise it another 1/8" just to see if that will cure the cv joint binding.
chompsticks
Hmmm.... I dunno if I will spring for Ksports or not then because I drive too much and too hard for my own good... 20,000 miles and a new set of tires already... Although getting another inch lower would be superb!
chompsticks
Fronts I am right at 24 in the fronts and the rears I am at 23 and 3/4-7/8 eyeballin it. All I gotta say is that I have been working at it to get the fronts down another inch from stock settings on tanabes.
Zero2Endless
You should do the other side of the rear shot. It really emphasizes on the window graphic...which let's face it...is the number 1 design cue on the Cube.
501
Zero2Endless wrote:You should do the other side of the rear shot. It really emphasizes on the window graphic...which let's face it...is the number 1 design cue on the Cube.
hello what a suberb idea :facepalm: more pics to come :biggrin:
501
[quote="chompsticks"]Fronts I am right at 24 in the fronts and the rears I am at 23 and 3/4-7/8 eyeballin it. All I gotta say is that I have been working at it to get the fronts down another inch from stock settings on tanabes.[/quote
i am at 23 1/2 on the rear
i will let you know how the fronts turn out if i play with the hieght
think i may be doing a different set of wheels here shortly ;)
Zero2Endless
Yep yep that's how I do it...however I haven't even uploaded my pics yet! WTFudge. Ugh I need to shoot more ahhh.
Zero2Endless
501 your making me regret not getting 16s LoL. Those are the 513s right? Or are those the real thing?
501
513 yes
please post up pics....i know there are some good looking cubes out there
well here is another just a little tease
sup_mario
Wow. it looks very awesome man. I love it.
CubeNoob
Car: 2010 Pearl White Cube, 1992 Black 240sx
Cube with TE37V's coming soon
EDIT* what are the specs on your tires?
Zero2Endless
Whooop whoooop that's a sick front profile. Ooooh man I wanna go lower! AHHHH.
Noob... real te37s? How big too?
501
EDIT* what are the specs on your tires?[/quote]
16x8 + 15
16x8 + 0
Tire size, not wheels.
Good work on the camber - I posted an article on adjusting the camber on the Cube (and Versa), since I was one of the first to drop a Cube (3 weeks after the first one arrived at the dealer :) ).
Makes me regret my 17's. Goin' shoppin' - brb! ;)
CubeNoob
Zero2Endless wrote:Noob... real te37s? How big too?
all ill say right now is.
yes they are real and a they are 15's. gonna see how they fit before i give out too much info hahaha
and to OP i can see your running a 195 in the back but what are the other specs?
for example 195/xx/16 rears and XXX/XX/16 fronts
Zero2Endless
I put my wheels up for sale...I'm going to put pics up in the morn. I'm going to sell them with tires for 800 the tires only have like 6k on them they are basically brand new!
501
tire size is 195/50/16 front and rear on my set up
Nismo V
Car: 2007 Nissan Versa 1.8S 2008 Scion xB 2.4L
Love the Flushness.. :bigthumb:
randode
not low enough for me.
501
yea i hear ya!! its not low enough for me either
going to lower it some more here soon, also rocking new wheels
damian666robin
Car: 2009 nissan cube
looks great the way it is man those 5zigen wheels really stand up
Return to “Cube Forum”
