MaXimaSE »
https://forums.nicoclub.com/maximase-u73877.html
Sun Mar 30, 2008 8:19 am
Alright, so It's been a beautiful weekend; well almost.
I looked at the suspension bushings up front, and well they are soft/cracked and falling apart. Im going to pickup new bushings can anyone show me a link that allows you to get the whole front end done.
I recently had the car aligned and tires were rotated before hand.. I also hit black ice about 3-4 months ago when Winter was at its worst this year and smacked into a curb on the right passenger front before the car was aligned.
After I got the car aligned, all was well for a couple weeks and then I went on a good 50-60 mile cruise and started noticing the passenger front tire rubbing the rear of the wheel well when the wheel is turned to the right.
The wheel well makes contact with the Contact Patch on the tire and where it meets up with the sidewall, I need to get this fixed because you can see the well looks rubbed and this is causing a small peice of metal to be exposed from under the well.
The tire is also taking some damage, you can see small slits on the contact patch.
This only affects the passenger front while turning the wheel to the right and turning left to return to center..
Things Ive Done;
Jacked suspect side up and shook tire to see If I could get any freeplay.. I got no kinds of play when I rocked the tire at 3/6 nor at 12/6
I inspected the bushings(they need replaced) , CV Boots, Tie Rods, Ball Joints.. I didnt see no tears, evidence of loss of grease from the Boots, the tierods were tight and same with the balljoints.
