motoguy128 »
https://forums.nicoclub.com/motoguy128-u46857.html
Thu Mar 08, 2007 4:28 pm
This is correct. Thsi is NOT a thermostat. All the way to the cold position is 0% heat. the middle is 50%, to the left is 100%.
Also note the system ALWAYS works in this manner, even with the A/C on. So in the summer, the A/C compressor runs no matter when the heat positon is. It reheats the air after it's cooled off. The compressor cycles on and off depending on the temperature of the evaporator coils. So the hotter, more humid and faster the fan speed, the more often the compressor will cycle on. SO you will not get better mileage by turning up the temperature control in the summer. Only by switching to recirculate or reducing the fan speed.
