OK I am tired of the run around at the shop. So I am am trying to find the most likely cause, recall, or "Oh Yeah. On a Fronter do this" answer to the P1441 code. This, while not threatening, casues the "Service engine soon light" to come on. It elimintes the usefulness of the light for any more serious condition as well. If it stays on full time that is. I would appreciate an all knowing Nissan kinda answer if it is possible.
the definition of the code is below:
P1441 EVAP System Flow During Non-Purge Conditions.This deals with the purge solenoid, vent solenoid, charcoal canister, all the vacuum lines in this system, as well as the gas cap. Any one of these components may contribute to this code being set. All the wiring should be tested including the connectors for any problems. Vacuum lines should be checked for cracks or loose connections. The canister may be damaged or not working properly.
The site this came from:
http://www.actron.com/faq_deta...id=14
