Grim99CV »
https://forums.nicoclub.com/grim99cv-u237280.html
Thu Jun 12, 2014 9:42 pm
2000 Q45, 170k miles. A couple weeks ago this code popped up. The car started idling rough and had a little loss of power and even occasional stalling. Read that one or more coils can be the culprit. Decided to change all of them with Hitachi's on my brother's discretion (his car). Cleared the code and started the car. Idle remains the same, although when driving power was restored a little. So now I'm reading that the camshaft sensor (or crank angle sensor) can be the culprit. I cleaned the male and female harness plug with electrical contact cleaner. Still stumbling. When driving my brother says the TCS and SLIP lights flash off and on, but the CEL has stayed off (code shows when I plug in my Torque app). Would replacing the CAS ultimately fix this? Harness has no physical damage, but could there still be unseen damage? Anyway of testing this? Any help is appreciated.
P.S. I've been familiar with mass airflow sensors causing these symptoms, which I did clean, but with no code regarding it, I have kind of ruled that out.
