Ah, I see. There are no TSBs about this combination of engine codes. I'd begin with verifying that the upstream oxygen sensor harnesses, coil packs, and coil pack harnesses are secure and that there are no air intake leaks (be sure the engine air filter is still present as well). Loosen and retighten
these ground screws also. Here are the locations of the oxygen sensor plugs:
P1148 & P1168 can
only be caused by oxygen sensor faults according to the FSM, so something with the harnesses, wiring, or possibly both O2 sensors themselves (but the chance of both failing at the same time seems remote) is to blame here. Nonfunctional upstream oxygen sensors will throw the air/fuel ratio off and can certainly cause your other two codes and other associated effects (black smoke out the tail pipe).
Hopefully those will be gone and then we can deal with P1320.
