I just started getting this code a couple of weeks ago for the map/barometric sensor solenoid. Started happening after not driving the car for a couple of weeks. Cleared the codes and comes back on the same day. Car idles fine. I took the tube off the map sensor or boost sensor it says on the actual sensor to check for a good vacuum and leaks. I blew into the tube and it isnt obstructed. It has good vacuum and the car started to idle rough and gave the p0105 map sensor code until I put the tube back on. P1105 code did not come back on until the next day this time. Car runs fine no stuttering or hesitation. Is it a good idea to put some seafoam thru the tube from the map/boost sensor to the solenoid? The solenoid is buried under the intake plenum and I'm not going there. I'm willing to try anything except taking off the plenum. Car also has p0330 KS code and p0500 vehicle speed sensor (A) code but I had those for the last 5 years and never failed inspection but now its inspection time again.
Pnoid tech bullitandy even maxnix and anybody else please help
