Kompresshun »
https://forums.nicoclub.com/kompresshun-u133574.html
Wed Mar 28, 2012 6:05 pm
I've been having some odd transmission issues with the Maxima the past few days. I blew a transmission cooler line last week and had to top it back off with 2 qts of fluid, which I managed to put the wrong fluid in it, but that has been remedied now. I did a fluid flush yesterday and filled it back up with the proper fluid, but it's still shifting rather odd. It was shifting good and firm, even with the wrong fluid in it. All of a sudden a couple of days ago it started shifting a lot softer and having a harder time downshifting, along with feeling a little sluggish.
It also has been having a hard time when it's cold between 1st and 2nd - it'll slip and feel like it takes a second to go in gear, then once it does it feels like it slams into gear if you're not being gentle. It only does it once though and won't do it again until it sits for a few hours. I've been trying to do some research and see what I need to do about this, because it's obviously not right and I don't think it's something I can diagnose myself. It didn't start acting up until I had the issue with the cooler line.
Tonight I decided to hook my OBD code scanner up to it and it found a P0325 Knock Sensor code, which seems like it could explain some of the symptoms as well.
So at this point i'm still rather confused though. Should I go ahead and take it to a transmission shop, or should I take it to Nissan and let them run Consult on it first? I would hope that the transmission isn't trying to crap out already... it seems more like a valve body or torque converter issue, but some more insight would be greatly appreciated. Thanks guys!
