kevin924 »
https://forums.nicoclub.com/kevin924-u70623.html
Fri Dec 11, 2009 6:03 am
Just want to share my experience with P1444 code. A month ago, the code pops up. Took out the purge valve. You can blow air through the valve. So, it appears to be stuck. Before I put on the new one. I thought I might be able to clean it out. And it worked, at least for a few weeks now.
Here is what I did. Buy a can of MAF cleaner, around $7. Spray the cleaner in the valve pipe. And let it soak for a couple of minutes. After dry, try to blow air through the valve. If you feel resistance, it works. Just keep doing it, until you can't blow air through it. Then, put it back on. It should work for a while. Not sure how long, but for $7, it is worth trying.
