The problem(or one of them) in my situation is that the car doesn't ever reach operating temp! lol. I had to wait until my car overheated before I could check the fans.maxhopper97 wrote:Try running the car in your driveway to normal operating temp and above(with the heater off); and see if the fan kicks when the engine temp excedes approximately 170*. Your electric fan may be faulty.
On a side note, I would never recommend putting any kind of stop-leak in any part of your vehicle. It's a foreign substance that will, more than likely, do more harm than good. If you have a leak, fix the cause of the leak.
Wow, that is a great picture! Shows me EXACTLY what I need to see. Thanks a bunch.RED_DET wrote:If you don't hear any obvious sounds of gurgling coming from the system or the overflow boiling over, I don't think you are over heating. I think the gauge is not functioning properly. Normally the fans are designed to kit on around 210*.
Take the wire off the single wire sensor and ground it to the engine and see if the gauge moves. If so, replace it. If you fans aren't kicking on either, you may need to replace the other sensor as well. I will try to look at a FSM and see how you can check the voltages. But it sounds like you are not overheating, just faulty sensors. This will also make the car run differently, does it idle funny, any loss of power?
You could also hook up a aftermarket temp gauge.
