I guess I'll start off by pointing out that I'm a big dumb oaf that didn't use the VIN to verify correct parts when buying. So here's the thing I bought the parts about 3 years ago and never installed because I stopped driving the car so I can't just return them.
Car is a 2000 infiniti Q45 Anniversary Edition. From doing some searching on here I've been able to figure out that the spindle was shortened on the strut a some point during the 2000 year, so year 2000 cars will have either the original long keyed spindle or the new shorted spindle. See below.
Now none of the other parts have changed even after the spindle modification midway through 2000. If you look at the image I've inserted below you'll notice that the part numbers for the: hub, wheel bearing, spindle nut, are all the same for all model years of the car. I pulled the info by comparing part numbers from online catalog. I reassembled with all of my original parts including the washer and the spindle is to short to secure. The nut only goes on about 3/4 of the way. I'd like to reassemble without the washer since it will fit but I don't know what will happen if I tighten the nut up against the inner surface of the bearing. Doesn't anyone on here have a 2001 Q that they've taken the hub off the spindle? Do you remember if the washer was used or not?KingKarl wrote:One problem....Infinity has evidently modified the spline/wheel bearing/hub combo for the '97 to '01 Q45 to do away with the large, keyed washer that fits between the bearing race and the axle/hub retaining nut (now like '03 - '04 Q45). They did not tell me this and when I went to install the hubs....."chest pain, I've got chest pain!" Luckily, I called Justin Monday morning before I was schedule to be air-lifted to the Cleveland Clinic and he informed me of the change. I was still cranked as I had spent Sunday re-compressing the coil springs, removing the new mounts and seats etc., to get the strut assemblys ready to be shipped back to IOS for exchange. A little info about the change at the time of the strut assembly order would have been extremely helpfull.
Also the catalog had some strange descriptions for the struts which I don't understand. See the img below. Thanks for your help guys! Sorry if this post sucks I'm throwing it together as I can during work.
