RRRRB wrote:how much boost/power were you making on 16* timing
Also who clearanced the bottom end? there are lots of things that could contribute to the problems your having, and not doing the things that have been suggested could likely be the reason your having issues..
Straight 6 engines are very prone to bent cranks simply from improper storage or tipping it over etc...
The bearing pictures you posted doesnt look like a contamination issue to me thats generally more distinct and inconsistant..
Id suggest taking it to a reputable machinest to have all this checked, including the main line and perhaps have someone else assemble the bottom end... engines are not complicated as long as everything is inspected clearanced and put together correctly you WONT have issues... ive assembled quite a few engines many over 500whp and a few over 700whp and all are running to this day...
what type of oil do you run?
Bout 14 psi on the 6262. Should be just shy of 400 whp with my tune.
I did all the measurments. I used plastigauge on the mains and a mic with an inside mic on the big ends. I'm a mechanical engineer. I do downhole tool design for the oilfield so I'm well versed in tolerances, mechanical measurements, assembly, etc. I assembled the original RB30 which like i said ran for two seasons filled with racing. I had also replaced the rod bearings the first time I built it.
I agree with what you said about engines. They are simple and should run correctly as long as like you said everything is checked correctly. Some people make them about to be some kind of mythical beast that need an engine whisperer to be made to run properly. A shop that wanted my money told me if i reused my rings it would smoke like a chimney; they wanted to build it for me. I've rebuilt it twice now aligned the rings properly and it hasn't burned a drop.
Something is f*** with something. Here's the sequence of events:
Buy RB30 and RB25DE head
Completely disassemble bottom end - clean - replace rod bearings - reuse mains - assemble
Race for two seasons
Buy RB26 head - put on RB30 block without touching bottom end
100 km of driving - developes knock - disassemble, bottom end is cooked
Rebuild with new mains and big ends
100 km of driving - develops knock - and I imagine bottom end is cooked in same fashion.
Something to do with my RB26 head? Seems like a bit of a stretch.
If I'm gonna haul that thing into a shop I might as well have it forged :/. But I want to make sure it isn't some finnicky thing causing this that would be outside the realm of an engine builder.
I was running 5w30 Mobil 1 the first time it went, and it was just some s*** dino 5w30 this time. I was just running it for a bit and i was going to switch to German Syntec 0w30 which is more of a 0w40.
