I have a 1990 240SX wit the KA24E engine. As I've mentioned in a previous post (
zerothread?id=132756), my oil pressure has been low after rebuilding the engine. Since all my bearing clearances were well within the stock spec (according to the FSM) and switching to 20W50 had very little effect, as well as shimming the oil pump pressure valve, I was wondering if the low oil pressure could be caused by the pressure relief valve in the block where the filter is.
Here is how the pressure acts: At cold startup it'll go up to 30 and then quickly drop to 10 or less psi at idle. My head clatters pretty badly, although it seems like it's only one rocker arm that's doing it. As I rev the engine, the pressure will go to around 40psi at 3k rpm, and stay there no matter how high I rev it after that (I haven't gone over 4500 to not damage the engine). Since I've replaced the oil pump yesterday and the pressure acts the same, I know it's not the pump or its valve. The only other thing I can think of except for something majorly being wrong with my rebuild, is that little spring driven ball (FSM calls is Oil Pressure Relief Valve)in the oil filter location. But I also know it doesn't take much force to push it in, so how could it possibly be responsible for my major oil problems?
Please give any advice you can, I'm really bummed out about my lack of success with this rebuild. I hate hearing my rocker arms clatter like on some beat up old truck and I don't drive the car now because I don't want more damage to occur.
Also, I was wondering if the addition of the turbo oil feed line could be responsible for such an unusual oil pressure drop? I do have a restrictor on the feed line, installed at the turbo end, so that the turbo seal doesn't get too much presure, but who knows? Then again, lots of people have turboed their KAs and don't seem to be having any problems with oil pressure.
sil80
Modified by sil80drifter at 3:30 PM 9/6/2005
