float_6969 »
https://forums.nicoclub.com/float-6969-u780.html
Thu Oct 12, 2006 6:21 pm
As was stated earlier, if you're trying to pull the pan with the motor still in the car the oil pickup will hang up on the baffles in the pan. You will have to do one of two things, either take out the 2 bolts on the oil sump (I don't like this method as re-installing them sucks, especially if you drop a bolt in the oil pan) or take the nuts off the bottom of the motor mounts, and the 4 nuts (2 on each side) holding on the subframe. That will allow the subframe to drop down away from the motor enough to pull the pan without removing the pickup. The downside to the last method is that you might need an alignment afterwards. I've done it like this 3 times on KA's and never had alignment problems afterwards, but it's still a possibility.
