wooramsehttps://forums.nicoclub.com/memberlist.php?mode=viewprofile&u=113&sid=920d101babdda8aed892b1c7b8187861OIL LEAK No idea what it isFri May 16, 2014 10:41 am
Postby
wooramse »
https://forums.nicoclub.com/wooramse-u139305.htmlFri May 16, 2014 10:41 am
I noticed oil leaks while I was refilling the windshield washer and I guess it's from the timing chain case but not sure.
My G is 2008 G35xS.
Have you guys had this issue before or would you advised what causes it and fix if needed?
Postby
wooramse »
https://forums.nicoclub.com/wooramse-u139305.htmlFri May 16, 2014 4:39 pm
Yes, it looks like it is. So the reason is just due to wear and tear? But I don't think it's a part of wear and tear area. Now I'm wondering how serious it is. Should I bring it to dealer and get it fixed? Any advice?
Thanks in advance.
Postby
audtatious »
https://forums.nicoclub.com/audtatious-u2438.htmlFri May 16, 2014 7:45 pm
I doubt it's serious. I'd check the bolts are torqued down properly first and then replace the gasket and any O-rings before worrying about it too much. If you are still unsure then I would have it checked out.
Postby
wooramse »
https://forums.nicoclub.com/wooramse-u139305.htmlMon Jun 09, 2014 6:13 pm
Actually it's not from the valve cover. It's from the timing chain cover somewhere the gasket. Cannot even think about taking it off since it will be the big job. So just cleaned the oil and keep monitoring if there is any new leak
The valve timing control solenoid is right there. It uses a steel coated gasket and its fairly easy to change. Snugging it down might stop it too.
Did somebody spill oil there during a change?
Clean it good and keep an eye on it.
