Check out below on how to replace the PCV valve. Its pretty straightforward and seems like one doesnt need to remove any of the intake manifolds.
zer...0-qx4
Replacing the PCV valve would help but is not a fix to the problem.
Try the below. I will be doing that soon when I replace my PCV valve. Pwnin suggested that to me sometime back, about installing an inline catch can and below is what it is is my understanding.
zerothread/186408
I remember coming across a howto with pics for the oil cooler as well if you pin the leak down to that.
Modified by ugharin at 4:01 PM 1/27/2010
