Hey guys,
i have an rb25det, all stock everything and im pretty sure i have oil in my cooling system. i flushed the coolant today and it comes out dark, dark, dark green, almost black. however, it(the supposid oil) doesnt float on top. i tought oil would still float on top of coolant, but its all mixed in together. anyways, the black s*** in my reservior is a lot more like motor oil so yeah, its oil...damnet.
so heres my question, what are the chances that its my stock rb25det turbo leaking oil into the water system and not a blown head gasket or worse...dare i say it...cracked block? im really really hoping its just the turbo but after some searching, i still dont know if thats possible with that turbo or any water and oil turbo.
if i do a leak down and/or compression test, would either of those point out a blown HG or cracked block? also, i checked the dip stick and it looks pretty clean with just oil so it looks like its just oil in the coolant and not coolant in the oil. i guess ill drain the oil some time this week and see if i see any coolant. if there was coolant in the oil, will there be traces on the dip stick?
anyways, any advise on how to proceed would be great. if its the turbo, sweet, cause i've been looking to upgrade that mofo anyways! blown HG, ok, that sucks, but i can fix that. cracked block, damn, what a waste.
thanks,
michael
PS. car runs fine and temp stays in the middle. no smoke, no noticable power loss, no over heating.
