Oil filter balls....
centralflZ
Car: Drop Top 40
I just got a call from my car being in the shop, and they told me i didnt have any oil pressure, so they changed the gauges and still nothing....They removed the oil filter "tree" and they said that one of the balls were missing inside of it, so they told me to go outside and do they same to my spare engine, and I had both balls in there, but one was in great condition, was able to push down on it, but the other was all messed up, and the spring was no good. I was curious if this would cause me not to have oil pressure? what are those balls for? I will try to explain it if you need me to. Any help will be helpful... Thanks
Heres the pictures, Don't mind the gunk and crapt this is the old engine.
Modified by centralflZ at 3:27 PM 10/1/2009
ztommyx
balls? lol.replace the whole pump assembly orjust replace the sending unit/sensor which usually go bad.
ps. you just wasted money on the gauges
centralflZ
Car: Drop Top 40
yeh dude, ill get a picture if my camera will work. right behind the oil filter tree neck thing, if you remove that, there will be two balls. I didnt buy the guages, they just swapped other ones on there to see if its that...I'm going to have them try an OPSU.
andrez
Car: 1990 300zx na / 1995 f-150 4x4 / 05 focus xr4 99 blazer s-10 jacked
so right now you own a z with only one ball
centralflZ
Car: Drop Top 40
yup. but i need some serious answer people.
ztommyx
i don't know what to tell ya.. looks like one of the bearing is gone... or better yet, damaged
but it's on the block so i don't know what to tell ya... maybe someone who has had this mishap before tell you.
itsa300zx
Car: 1990 300zx NA W/TT swap
2011 Nissan Rogue S
2008 Highlander SR5
Those ball bearings act as check valves, so the oil only flows one way.
centralflZ
Car: Drop Top 40
so this would effect the oil pressure reading then?
centralflZ
Car: Drop Top 40
i found out they are check valves, and if these arent working correctly i will not have oil pressure, so im going to nissan tomarrow to order 2 of them.
tg
Yes they are check valves, if you take the good spring and the good ball from your spare you could theoretically swap it in and it should work, BUT its probably a cheap part anyways.
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
I'm pretty sure only the one side shoudl ahve the check ball, the other side is a solid d!ck, if that disk is off as in the pic that might be an issue but I suspect you did that after the fact
is the oil pan dented? the pickk up in thest hings is desinged so taht when the pan gets dented just a little it basically plugs the pickup and you get no pressure
cjrboy14
Car: 92 300zx NA
andrez wrote:so right now you own a z with only one ball
lmao
centralflZ
Car: Drop Top 40
So, if ones supposed to be solid, what is the other one supposed to be like? When I go to Nissan today, I'm going to order two of them, and replace both of them for the hell of it...Whats the easiest way of removing these?Thanks
rtkota5point9
Car: 1991 300ZX TT 5spd 2+0
evildky wrote:the other side is a solid d!ck
Is it really? lol
