Have you tried a high mileage oil to see if consumption slows? Perhaps you should try replacing the PCV valve; if it's malfunctioning, oil consumption may result.Chuck Tribolet wrote:My '01 has 211,000 miles, burns a quart every 500-1000 miles I think (I don't track closely, just check the level every other fill up and add if required).
There are enough horror stories about high-mileage oils on Corvette Forum, that I won't use themTowncivilian wrote:Have you tried a high mileage oil to see if consumption slows? Perhaps you should try replacing the PCV valve; if it's malfunctioning, oil consumption may result.Chuck Tribolet wrote:My '01 has 211,000 miles, burns a quart every 500-1000 miles I think (I don't track closely, just check the level every other fill up and add if required).
Horror stories? Got any links? I haven't read of any issues as a result of HM oils. High mileage oils have more robust additive packages (anti-wear and detergency), are on the thicker side of their viscosity grade, and have seal conditioners to attempt to slow or stop smaller leaks or weeps.Chuck Tribolet wrote:There are enough horror stories about high-mileage oils on Corvette Forum, that I won't use them
PCV valve is something to check, but IIRC, it's a major pain.
wisehunter1 wrote:Yep pretty normal. Just do a little search on the forums and you'll find several proposals. Speaking of.. thanks for the reminder. I;m sure I need to add some more but I've been too overwhelmed with exams/school.
