Towncivilian wrote:I tend to avoid any engine oil additives. The engine oil formulators spent millions of dollars in research & development, testing, etc of their oils, why play chemist and put some bottle of gorilla snot in your engine oil because it claims to clean better? Most of the time such additives are based on harsh solvents, and should they loosen large chunks of sludge or other deposits, the oil pickup screen can become clogged and there goes your engine...
Yes I agree, and would only suggest this if he is going to pull the pan and clean the screen anyway.
I did this on an engine, added 1 qt of cleaner run for 20 mins at idle, then oil change. I didn't pull the pan, I was lucky !!!
