Oh NO!!! crack in the front bumper fixable?
95.240AZN378
Car: VW
So New Years i went to the city to party, and as i was backing out of they guy's driveway, i scraped, bad. I just thought it was going to be scratches on my lip, buuuttttt...... lets have the pics do some talking.My question is do you think that this is is fixable? If it is, then what steps should i take to repair it?AND just because.... the new 370Z!!!Thanks
blacky_s13
Car: 1989 240sx
Well the oem bumper is really flexible compared to the aftermarket body kits (fiberglass). I would use a type of flexible epoxy to get the bumper in tack. Then sand it down with 100 grit sand paper. Then a light coat of bondo to cover up the epoxy and try to get the original shape of the bumper. Sand bondo with 150. You might need to to the 2 or 3 times to get it just right. After every layer use higher grit. To get the surface smoother. Then prime it. If you do it right it should hold up nice. I cracked my Lip commin out of a friends drive way. And did the same. I'll post some pics for ya later. Good Luck
Modified by blacky_s13 at 1:44 PM 1/3/2009
darens13
Car: '93 240sx, '90 chevy 1500, '49 dodge pickup
i bet it could be fixed. i would probably take it off and reinforce from the backside of the bumper with some fiberglass, but im sure there are some other good methods to fix it.
95.240AZN378
Car: VW
What i'm worried about with fiberglass is that i read that it doesn't really stick to the plastic very well, and i'm just worried that the first big bump i hit, it'll crack, and I'll be here again.
blacky_s13
Car: 1989 240sx
If you sand the bumper with low grit sand paper first the epoxy should hold up. But you should reinforce it like darens13 said.
Blacky_s13
R6_240sx
Car: 1997 240SX LE, 2004 YZF-R6, 1980 Celica GT
Easy fix. Just make sure YOU DO NOT use any type of body putty (Bondo) or fiberglass resin on it since its urethane. You have chances of it cracking in the future if you do.
What you need is a plastic filler/plastic weld, it's practically the same thing as body putty, but made for plastic parts. A good one I recommend is Evercoat Poly-Flex or Fusor 114, but there's plenty of other good ones.
You'll need a reinforcing mesh on the backside of the hole so you have something to lay the plastic filler on.
Go to your local Auto Body Paint Supplier, they'll have everything you need.
Thrwnsprkz
Car: 240sx
no fiberglass, no bondo...
go to the bodyshop supplyer and ask for the correct product from "Fuzor" adhesives.
they make a plastic weld that is much stronger than most off the shelf stuff...remove the bumper and use it as directed, clam together and reiforce behind it aswell.
in all theory youd be best off prepping the surface, sanding away the material a bit with some sandpaper so it aheares even better but then that woyld require paint and body work, post oporation aswell...
GL with the fix
R6_240sx
You're lucky cuz I'm doing research right now for shaving off my license plate so here's a list of products you can get:
Fusor go on website for local supplierPlastic Finishing Adhesive, 114Bumper Reinforcing Mesh, 700
3M Duramix Semi-Rigid Plastic Repair, 04240-You need applicator gun which is Automix Dispenser, 08117Reinforcement Patch, 04904
SEM go on website for local supplierFlexible SEM-Weld, 39927 or 37908 for bigger onePlastic Repair Reinforcing Tape, 7006
Evercoat Maxim Urethane Adhesive, 887 (Fast) or 885 (Medium)Multi-Purpose Repair Panels, 828
IMHO though for the reinforcing mesh, go to Home Depot and buy one of those Fiberglass screens that you use to put on screen doors to get fresh air, but keep bugs away. MUCH cheaper.
95.240AZN378
Car: VW
Thanks for the help guys, i'll get around to doing this soon!I might post up how it goes.
95.240AZN378
Car: VW
oh and any suggestions on the lip???I have a chunk missing, and i'd like to fix that too.
xC4RNAG3x
Car: 2003 Mitsubishi Eclipse GTS 1993 Nissan 240sx Hatchback
Zippy Ties
-They fix everything
95.240AZN378
Car: VW
xC4RNAG3x wrote:Zippy Ties
lol 4 zipties holding it on, i'm talking about the chunk missing though.
carps13guy
Car: 91 coupe ka
i used some stuff called 40/40. its a two part epoxy that uses a special gun, and a tip that mixed the two. its gnarly stuff. when i removed my lip the pop rivets tore the stock bumper. that stuff along with a plastic mesh made it really strong. it takes overnight to dry, but its a quality product. i dont reccomend buying all this, but find something similar/cheaper and use that plastic mesh stuff on the inside of the bumper, it should reinforce it real nice.
R6_240sx
95.240AZN378 wrote:oh and any suggestions on the lip???I have a chunk missing, and i'd like to fix that too.
I gave you everything you needed bro...
keith0486
i say duct tape it duct tape holds everything together jk do what r6_240sx said it will work fine.
silpena
Car: Nis1993 san 240sx super hicas(wrecked)
soon to come to s-chasis
rb_240sx pretty much gave u everything u need to know. I would recommend the evercoat urathane expoxy. Get super fast drying type. Handling time is like 1 min and curing is like another 1min so u dont have to hold it by hand for a long time. It sticks excellent, it flexes just it would before and sands easily. I wouldnt settle for less but its expensive. If u want to know how to recreate your lip with the stuff i can tell you. All i to say is two putty spreaders is all u need.... no tape or gay zip ties.
Armstec_S13
Car: S13 Coupe
Ok well here's my $0.02, I bought a zenki front lip awhile back for 20 bucks but it was cracked almost in half, I went to autozone and there it this bumper repair kit made by the company "bondo" it's a bumper apoxy that works great it dries and bonds to the plastic very well, its sandable and paintable, I used it on my lip and even "molded" a piece when a chunk was missing from the lip, it came out great, I've scrapped and hit my front lip so badly (stupid chicago streets and speed bumps) and it held up great, is flexable when it dries I traded a chuki bumper for a silvia bumper that had a crack on the top of it and I decided to use that stuff and it works great, it come with the reinforcing mesh too, it's in a small tube you gotta mix it together, IMO it's the best stuff without having to spend crap load of money, but anyways its about $6.99 a tube remember tho you still gotta paint the bumper
livinglegend2100
carps13guy wrote:i used some stuff called 40/40. its a two part epoxy that uses a special gun, and a tip that mixed the two. its gnarly stuff. when i removed my lip the pop rivets tore the stock bumper. that stuff along with a plastic mesh made it really strong. it takes overnight to dry, but its a quality product. i dont reccomend buying all this, but find something similar/cheaper and use that plastic mesh stuff on the inside of the bumper, it should reinforce it real nice.
does it come out of the mixer tip black? cuz theres some stuff like that we used at the shop i used to work at. pretty much the best bumper fix ever...
carps13guy
Car: 91 coupe ka
ya it does come out of the mixer tip as a black color. it dries black also, but that stuff is great. although i was talking to my uncle that loaned me the gun, and he was telling me that the company who produced it is not making that epoxy anymore. he told me that the company DURAMIX used to produce it, but now they only sell a weaker version that doesnt compare . this sucks cuz it worked wonders. well, at least i was able to use it and see how great it was.
98koukile
Car: 1998 Nissan 240SX LE
I suggest finding a navan bumper but I like spending money haha
95.240AZN378
Car: VW
98koukile wrote:I suggest finding a navan bumper but I like spending money haha
Accepting donations now
