Offset question
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
RickT2012
Car: 1989 240SX hatchback
2012 Versa S sedan
Later this year I'm getting some new rims and I'm not sure I understand what offset actually is. From what I understand, a wheel with low offset or negative offset will stick out further. Is this true? I want an aggressive looking fit on my Versa with deeper wheels. What offset should I get, and what is backspacing?
sgtxnoobz
Car: 2012 VHB Silver
When viewed from the front, offset is the distance between the hub mounting surface and the center-line of the rim. Positive offset means the hub surface is further out than the rim center, and negative is behind it. Offset effectively determines where the wheel is in the wheel well. A more forward hub (positive offset) tucks the wheel further in, and a negative offset moves it farther out.
RickT2012
2012 Versa S sedan
Thank you, that helped quite a bit.
Return to “Versa Technical Discussions”
