sepulchralx wrote:ur the dude i talked to over the phone... good deal! how do u plan on tuning the thing? can u actually use a wideband? is propane considered higher octane than gasoline, or doyou have to run less boost to avoid pinging?
I am going to tune it with a megasquirt ecu. Im only using the megasquirt for adjusting my timing B/c the fuel is self regulated.The wideband works the same as it would on gas.Propane is = to 110 octain of fuel. So in reality you can run more boost.The rock crawlers around here are running 15:1 compression and 20psi of boost on propane. Which is insane on any setup with that kind of compression. But with the intercooler I built and the cold intake temps takes the chances of detonation way down.
Darius wrote:I'm impressed with the enginuity as well. Great idea to use the IC as a heat exhanger! Have you considered running a water-to-air IC instead of that fabricated box and instead of water, use propane? Keep it up and keep this thread updated with your progress.
Thanks, Honsetly I have not looked at the water coolers. The reason I used a A/c condenser is it had to be able to accept high pressure. The propane averages 200psi in the lines in the winter and around 250psi in the summer.
sepulchralx wrote:darius makes a good piont go to
http://www.ssautochrome.com... get an air to water intercooler for cheap and use that.... don't run ghetto sheot.. your welds may have pores. Also you should move that convertor; its so close to the turbo and your hood probably won't close. You should also reverse your charge pipes. I don't like the criss crossin.. never did on Rb setups with stock manifolds
Its ghetto B/c its the first one ever built and my first time Tig welding aluminum. I pressure tested my welds at 180-psi and soapy water. Had a few leaks at first but I fixed them. It tucks under the fender and No one will ever know im even running a intercooler.
