OEM stero lights up but no output?>
Postby itsj30t » Mon Jul 23, 2012 5:38 pm
I recently just picked up my J30 and it turned out that the head unit does not work. It lights up and all but no turn on? any input on this?
Thanks!
itsj30t
Car: 1994 Infiniti J30t
Re: OEM stero lights up but no output?>
Postby driverdriver » Thu Jul 26, 2012 6:49 pm
The Bose headunit(actually made by Clarion but branded Bose) is a weakness on the J30. The first time, mine failed it lit up but did not work. Your options are to pick up a working unit on ebay, Clarion will repair your unit (don't know what the cost is nowadays)-you have to ship the unit to them or go aftermarket.
Currently in the Garage:
Daily Driver #1: MINI Countryman
Daily Driver #2: Mercedes-Benz B-Class
Spring/Summer/Fall Screamer: '94 Infiniti J30t rare gold package w/HICAS (13+ years of ownership and she still looks&runs like day one!!!)
driverdriver
Car: NICO's longtime resident Canuck!!!
Postby NASCARLANCE » Sat Aug 04, 2012 5:47 pm
I went the eBay route and got a 2003 or 2004 in-dash 6 disc changer out of a 350z.
Plugs straight into the wiring but it is wider and taller than the original head unit.
I had to dremel and file the opening in the surround to make it fit.
It's a pain to get it to fit just right.
You have to take some off of all 4 sides of the opening to get everything to fit correctly.
When you get close you have to take some off,
then test fit,
then take some more off,
then test fit again,
then repeat this about 1000 times and it fits perfect.
BTW, that surround is not solid wood, it is a layer of thin wood, sheet metal and another piece of wood laminated together.
Cartoon(over Cayenne Red) on Black/Red '11 Juke SL AWD /^\ Black on Black '95 J30t /^\ Rust on Dirt '88 Hardbody
NASCARLANCE
Car: 2011 Juke SL AWD
1995 j30t
1988 Hardbody
Postby J30inthe sun » Sat Aug 04, 2012 11:42 pm
This head unit is from a 2003 Nissan (sentra or pathfinder, I would have to check again). It required a small mod to the radio mounting bracket by re-drilling the cage screw mounts so the unit fit flush with the wood trim. The factory wiring harness was slightly different, it did plug right into the factory harness but this head unit had a power out which matched up to the ground on the factory harness. So I cut that wire in the harness.
Now I have 6 disc of MP3s. about 100 songs on each CD.
J30inthe sun
Car: 1997 J30
Postby driverdriver » Sun Aug 05, 2012 7:11 pm
Nice job J30inthesun!
driverdriver
Postby J30inthe sun » Thu Aug 09, 2012 7:47 pm
driverdriver wrote:Nice job J30inthesun!
Thank you.
J30inthe sun
Car: 1997 J30
Return to J30 Forum / M30 Forum
