julio wrote:I know the pressure range is 0-230psi, but has anyone figured out if the front lock up % is linear with pressure? Full Race Geoff had his car running 50-60 psi, but like I said, who knows if its linear or not.
The R35 is a bit of a curve with voltage. They use a solenoid direct acting on the clutch pack.
For the R32-R34, I really don't think it would matter much, because you won't know the actual amount of slippage in the clutch pack. All you see is "commanded" torque to the front wheels, not what is actually going there.
