Buy or sell Nissan / Datsun cars, trucks, SUV's and crossover Vehicles!
NY: 1990 400 WHP SR S13 240SX hatch. Track built/tested
Postby freakyjason » Tue May 15, 2012 4:50 pm
SOLD
It is with great sadness that I create this thread. But, it's time to move on, so my loss could be your gain.
Anyway, it's a 1990 s13 hatch SE model. I have no idea how many miles are on the chassis, but there are about 2000 miles on the engine (and I've already done three oil/filter changes). The bottom end was assembled by White's Speed shop in Cicero, NY and the standalone (Apex i power FC) was tuned by Morgan at Synapse Motorsports (which is a great shop by the way, I suggest you check out their website if nothing else). It put down 366 whp and 338 ft-lbs of torque at 18 psi (track boost level) and an estimated 395 whp on 22 psi. The car handles incredibly!! I mean, wow! In fact, I've had two instructors at HDPE events remark about how incredible the g forces were. Anyway, enough rambling, on to the parts list...
FYI, I have the rear seats if anyone wants them. they're in excellent condition.
Engine:
- CP pistons 9:1 compression ratio, 87mm bore
- brand new rings cut for 22 psi of boost
- Eagle rods
- ACL bearings
- ARP main hardware
- ARP headstuds
- ARC oil pan
- s14 oil pickup/strainer (bigger opening than stock SR)
- Mocal oil cooler with thermostatic sandwhich plate
- BRAND NEW OIL PUMP
- Brand new water pump
- Brand new timing chain
- Brand new timing chain tensioner
- JWT S3 Cams
- Tomei rocker arm stoppers
- New Valve stem seals
- Cometic head gasket (They're actually not crap, both White's Speed shop and BG at Enjuku racing suggested them over the coswerth. I know, news to me too)
- Z32 MAFS
- 72 lb MSD injectors
- JGY top mount fuel rail
- Walbro 255 LPH fuel pump
- Megan exhaust manifold
- Garret GT2871R .64
- Circuit Sports oil catch can
- Circuit sports Thermal insulating intake manifold gasket
- Nismo thermostat
- Turbo XS manual boost controller
- Apexi N1 exhaust
- Megan down pipe (with flex section)
- Isis (i think) HKS SSQV imitation BOV
- Front mount intercooler (no idea what brand)
- Custom cold air intake port with stopper (for the rain which can't get into the intake anyway considering the piping is not directly attached to the intake).
- Koyo radiator
- E fans (12" puller, 14" pusher) on a switch. stays nice and cold, even on the track!!
Brakes/Suspension:
- Stance GR+ Pro Coilovers (12/10kg/mm)
- Z32 Brakes
- Steel braided lines
- Hawk pads
- Circuit sport drilled/slotted rottors
- Megan Rear Upper control arms
- Poly Steering rack bushings
- Stance rear subframe spacers
- Custom Subframe Brace
- SPL front tension rods
- Megan Tie rod ends
- Nismo power brace (Custom equivalent)
- New front lower control arms
- New ball joints
- Poly bushings throughout sway bar assembly (front and rear)
Wheels/Tires:
- 17" 5 Zigen FN01R-C 8" front, 9" rear, can't remember the offset. They really do fit awesome though!!!!!!!!!!!!!!!!
- Toyo R888's with TONS of life left on them. 225/45 fronts, 255/40 rear. They are incredibly sticky!!!!!!!!!!!!!!
- *ALSO* includes spare set of 5 Zigen fighter rims with street tires on them.
Transmission/drivetrain:
- S15 Helical Limited Slip Differential
- B&M Short Throw Shifter
- Nismo Engine mounts
- Steel braided clutch line
- New master cylinder
- ACT 6 puck unsprung clutch
- ACT Heavy duty pressure plate
- ACT throwout bearing
- ACT Street light flywheel
Seats:
- Corbeau Forza Fixed back seats with stock belts
Body:
- Xenon front lip
- 180sx tails/wing
- Carbon fiber hood
Gages:
- AEM Ugeo Wide band O2 sensor
- Oil pressure (advance Auto brand)
- Boost (greddy)
- EGT (greddy)
- the Power FC gives a ton of different readings in real time (such as knock, duty cycle, timing, water temp, etc.)
The car really is excellent. It's an absolute blast to drive. it's fast, the torque curve is incredibly linear, and it handles better than some competition track cars (really, it does). I absolutely LOVE it, and part of me will die when i hand over the keys. If you need any additional pictures, ask and I will try to accommodate you.
ALSO!!! The car will come with EVERY spare part I own for the 240sx and for the SR20DET if you want (probably over $1000 in parts).
I'm asking $9,000 OBO
Believe me, it's worth every penny if not more.
Feel free to email me with questions (not comments): Mbsmit05@gmail.com
My new 240:
freakyjason
Car: 1990 240sx
Re: NY: 1990 400 WHP SR S13 240SX hatch. Track built/tested
Postby nissangirl74 » Fri May 18, 2012 11:27 pm
GLWS! Please let me know when this sells so I can mark the thread SOLD and lock it. Thanks!
Follow NICOclub on Twitter!
Friend us on Facebook!
Bella!
krash wrote: We just stay here hoping and praying that she'll start jogging again, but she keeps trying to convince us that we want a fat FWD chick with CVT.
nissangirl74
Car: 2013 MazdaSpeed3, '00 Honda Insight, '05 Frontier, '77 620, '72 240Z w/RB25, '68 510, '67 WRL411, '67.5 SPL 311, '64 Bluebird, '63 NL320, '60 Bluebird
Postby freakyjason » Sun May 20, 2012 10:26 am
nissangirl74 wrote:GLWS! Please let me know when this sells so I can mark the thread SOLD and lock it. Thanks!
Thank you very much, I will certainly do so!
freakyjason
Car: 1990 240sx
Postby xxfichtelxx » Tue May 22, 2012 9:38 am
If i can daily drive it then im super interested
xxfichtelxx
Car: Looking to buy my first nissan 240sx willing to spend 8000-9000
Postby freakyjason » Tue May 22, 2012 1:46 pm
xxfichtelxx wrote:If i can daily drive it then im super interested
I sent you a PM with my cell number. Give me a call so we can discuss.
freakyjason
Car: 1990 240sx
Postby freakyjason » Sat May 26, 2012 6:44 am
Bump. Still for sale!
freakyjason
Car: 1990 240sx
Postby freakyjason » Sun May 27, 2012 6:55 am
I did say OBO, right?
freakyjason
Car: 1990 240sx
Postby marshallpre1 » Wed May 30, 2012 8:44 am
can you send me pics (can't see them at work) to marshallpre1 at h0tma1l dot com?
Thanks
Jeremy
2004 G35 Coupe- daily/track
1994 SC300- NA-T- future track car
1997 Supra TT-PT67/Vi-pec/etc
marshallpre1
Car: 2004 Infiniti G35 Coupe
Postby freakyjason » Sun Jun 10, 2012 4:28 pm
Sold!! Mods, you may lock this thread.
freakyjason
Car: 1990 240sx
Postby nissangirl74 » Sun Jun 10, 2012 10:49 pm
Congrats on your sale! Thread locked.
nissangirl74
Return to Nissan For Sale
