The nsport piping already comes with the bosch welded.... You will need to make a cut in the pipe and weld on the new flange. I used the HKS SSQ bov instead of the bosch, it works fine. You need to plug up the hole however which the bosch was to re-route into the intake, I used the cap off the end of a walking cane stick.
-david, 93 ka24det
