Started short block assembly.
Start by cleaning your crank, when I say clean your crank, I mean you clean your crank. You need a microfiber wrag to do this. Your shirt, your dandruff, your dog, cat, whatever will find a way to get on your journals. Then you gonna have a bad time.
http://imgur.com/3os8J6k
Clean your cly walls, set your studs if you are using main studs. I recommend them if youre goal is big power or future plans for big power. Clean it all. Use rubbing alcohol or brake parts cleaner and compressed air to clean your surfaces and blow out your oil galleys.
http://imgur.com/t1T3bkb
Remember how I said to clean the crank? Yea do it again, and again. Anything gets between the journals and the bearings; you're gonna have a bad time. Clean it again.
http://imgur.com/IYyNWml
So this bearing is an older one I pulled from the mains before the block was sent to the machine shop. Even when assembled in the factory, there's chances that a small blemish or bur or slag if the thrust bearing is welded and not a one piece get caught in the assembly oils and this happens. Those lines are scratches, they can cause a tight crank condition, which, in lamest terms, is a bad time. Inspect EVERY part you put in your lower end.
http://imgur.com/KmQYx8U
This is a new bearing, did a mention to wear gloves? No? DO IT. Oils from your hands can cause bad times. Did you just let a bead of sweat fall into the block? You better find it and clean that s*** up right now. Your bottom end must be perfect. So perfect that I personally do not trust machine shops with assembling it for me. This is what a good bearing looks like.
http://imgur.com/7WgpRNa
When you have everything cleaned twice you can now drop your main bearings into the block. Un less you're building a complete engine in a weekend you go out and buy some assembly lube, usually green and think. Lay a fair amount on your bearings.
http://imgur.com/2zUOvg3
I've packed in for the night.
More photos to follow Showing the dropped in crank and piston ring tech.
