Sorry to hear your installer jerry-rigged ur swaybar install.
All he had to do was follow instructions or say it doesn't fit.
Good to hear ur rollin strong again.
What is wrong with people these days?
Or EXs are not beaters taking half-measure fixes.
To set the record straight for anyone wishing to do the swaybar install properly with the correct parts MAYBE??? Here is the lube my boyfriend uses.
He says one application should last for 3years minimum. He hasn't touched his in 2 years and says they're still perfectly lubed under there. This is in Cali weather though. Few freezing days mostly warm weather and no road salt. Either way that should not bother it.
Link to Harbor Freight site:
http://www.harborfreight.com/85-gram-su ... 93744.html
Description
Extend equipment life and protect your tools and accessories from wear, rust and corrosion with synthetic grease! This patented formula contains Syncolon® (PTFE) to outlast petroleum-based grease and keep your equipment in top condition longer. This waterproof synthetic grease is also dielectric, making it suitable for electrical applications.
Protects against wear, rust and corrosion
Extends equipment life
Waterproof
Dielectric
