EdBwoy »
https://forums.nicoclub.com/edbwoy-u213758.html
Tue Jan 20, 2015 1:24 am
Thanks for reporting back with your progress sergk.
Not trying to be funny here, but did you use the same size bell housing? You're not using a washer between the sensor and bellhousing, right? What you described sounds like the sensor is slightly pushed/ angled out.
Before going all out on the replacement, I'd first have somebody turn the crankshaft 2 or so turns while I got under there with a flashlight to see if the signal plate was really bent. Again, it is really hard for the signal-dependent systems to run with a bent plate (even if you pushed the sensor in) - and if they will run, you will most probably get a check engine light... Although you mentioned a code for crank already, so that might be it
