No Power To Interior
islandtuner242
Car: 1990 Nissan 300zx N/A 2+2 SOLD!!!
2003 Infiniti G35
Ok I Don't Know If Someone Must Have Put My Battery Terminals On Wrong But Now I'm Not Getting Any Power To My CD Player, Interior Lights And The Lights Under The Dash That Turn On When The Door Is Open.................. Also The Indicator To Let You Know The Driver Door Is Open (That Ding Ding Sound) Isn't Going Off Anymore But My Dash (RPM & Speedometer) Are All Functioning Properly & They Light Up When Thew Headlights Are Turned On :gotme :gotme Any Ideas?
Thanks In Advance,
Kadeem
aroche25
Car: 2007 Mazdaspeed 3 GT
Looking for a Z32 Slicktop
Check fuses by driver foot well, I had some thing similar and it was just that 2 of my fuses were blown.
islandtuner242
2003 Infiniti G35
I Just Fixed The Problem..... The Previous Owner Had Taken The Alarm Fuse Out & Never Replaced It Now Only Thing Left Is The CD Player
islandtuner242
2003 Infiniti G35
Thanks aroche25 by the way
aroche25
Not a problem, the cd player is probably related to some wiring behind the dash if the audio 1 or 2 fuses weren't blown, I would pull the cd player out and inspect the wiring check both power and grounds closely as well as any loose ends. If you cant find anything out of the ordinary use a multimeter and see if its getting power at all, it might be just a failed cd player.
Ace2cool
Car: 1991 Nissan 300ZX TT
1966 Datsun Fairlady 1600
2005 Suzuki GSX-R 600
1974 Honda CB550 Four
2009 Ford F150 Lariat
"Theft Room L" is most likely the fuse you had missing. Doesn't actually have anything to do with the alarm system, however. It's designed to blow whenever someone tries to hotwire the car and gets the wires mixed up and shorts them or whenever the stereo wires are shorted together, mimicking someone cutting wires on the stereo and causing a short.
If the interior lights are working now and the CD player is not, then I'd suspect bad wiring behind the stereo or a bad head unit.
junkyS13
Car: 1990 300ZX
1993 240SX
I recently purchased a (what i thought was a nice) twin turbo z. Pulling some old wires the the previous owner left not going to anything, I caused a short. "no big deal I will just pop in a fuse and all will be righted" but found the fuse was fine :confused: pulled the fuse to check and found someone put a bit of wire around the blades :facepalm: now my radio, dome light, map lights, clock, and I'm sure countless other things don't work and I haven't the foggiest idea where to start. Any help would be greatly appreciated
Kerry C.
islandtuner242
2003 Infiniti G35
@junkyS13 that's the exact same thing what happened to me...... They "jumped" the fuse by wrapping copper around the blades to allow power to flow through the fuse without the added protection..... So I just replaced the "Theft L" fuse (which was never there in the first place) and the interior lights started working just fine but the CD player's still out
junkyS13
Car: 1990 300ZX
1993 240SX
Lol I will check all the fuse again to be sure. I tested to radio power and I have 12v to both wires and ground is to the body, so I guess I burned the radio (Super old alpine so I don't feel too bad) the clock and dome lights on the other hand don't have power!
This got me hunting around the dash and I keep finding more spliced wires that goto nothing. :gotme the thing I was tring to fix was the speedo and temp (speedo jumps to 40 the sec. the car moves, Temp works till you put your foot down then starts dipping).
Sorry kinda feels like I thread jacked you
BigTDogg (MA)
Car: 1990 Nissan 300ZX TT
Temp may be a real problem. You can confirm with a Datascan or Nistune laptop if someone in your area has one. The two sensors are different for the ECU and gauge.
Speedo issue is your speed sensor, on the transmission.
Island, the CD player has it's own fuse, check the audio fuses. If they're ok, time to get a multimeter on the wires and check for +12V with the key turned to "on"
junkyS13
Car: 1990 300ZX
1993 240SX
sure enough it was the theft fuse (thought I checked them all, don't have the fuse panel door so couldn't figure out what was what) so many thanks for the help! now i just need to find a speed sensor and a nistune. still have a lot of wire to pull but i am going to check all the fuse to make sure no more are bypassed!
thanks Islandtuner & BigTdogg for the help,
Kerry C.
