Source: http://www.nissan-techinfo.com
Below is a list of Nissan Technical Service Bulletins. The complete TSB can viewed if available. You can also be obtain the TSB from the dealer, via a paid subscription to http://www.nissan-techinfo.com, and in some cases via a Google search.
Please note:- This list is intended for reference only. As always, contact your dealer if you have a concern.- These TSB's are not the same as Safety Recalls issued by Transport Canada or the NHTSA. - Many TSB's are simple service procedures and in some cases apply to multiple models. It does not mean there is a specific problem with your vehicle.- TSB's that deal with repairs may or may not be covered under warranty. Contact your dealer for detailed information.- The list will be updated periodically as new bulletins come out. The update date is shown on the title of this post.
From Nissan:
Tech Bulletin Nomenclature:Technical service bulletins (TSBs) are issued by Nissan to assist technicians with diagnosis and repair. TSBs address specific concerns or conditions such as rough idles, noises and rattles. These specific concerns can be the result of customer or repair shop feedback. The TSB for a specific concern or condition will provide an up-to-date engineering-approved vehicle modification, repair procedure or service part.
NTByyxxx - aa bbbb; Bulletin Title
Example: NTB92123 - SB Nissan; Aftermarket Chroming of Nissan Alloy Wheels Not Approved or Authorized
NTB = Nissan Tech Bulletin
yy = Year of issue (ie 08 = 2008)
xxx = Bulletin number (0-999)aa = SB = Service Bulletin, CP = Campaign
bbbb = 08 Rogue = Applies to 08 Rogue, Nissan = Applies to models listed, All Nissan = Applies to all Nissan models
GARMIN nuvi® PORTABLE GPS VOLUNTARY RECALL CAMPAIGN
Nissan is alerting customers who purchased a Garmin portable GPS unit with their vehicle or as an accessory that Garmin is conducting a Voluntary Recall Campaign on nuvi® brand portable automotive GPS units. Customers are encouraged to go to the Garmin website to check if their nuvi 750 GPS unit is affected, and follow the remedy instructions.
Garmin has identified potential issues in these nuvi units that can, in rare circumstances, increase the possibility of overheating, which may lead to a fire hazard. None of the reported incidents has caused significant property damage and no injuries have been reported.
Nissan has installed approximately 5,500 potentially affected Garmin nuvi 750 portable GPS units on the following Nissan vehicles: 2009-10 Frontiers and Pathfinders, 2008-09 Rogues and 2008-10 Xterras. Customers who purchased their Nissan vehicles equipped with one of the possibly affected nuvi 750 GPS units will receive a recall letter from Nissan in late September.
Customers who purchased a Garmin nuvi 750 GPS over the counter at a Nissan dealerships or another retail location are encouraged to go to the Garmin website to determine if their unit is affected, and to follow the remedy instructions.
NTB10084 - SB 2008-2009 Rogue; Noise When Turning
* IF YOU CONFIRM - There is a noise (clunking, popping, or bumping) when the steering wheel is turned. AND - The noise is coming from the top of the front strut assembly. ACTION Replace the left and right Strut Mounting Bearings with the ones listed in the Parts Information section of this bulletin. - Refer to section FSU, chapter FRONT COIL SPRING AND STRUT in the appropriate Electronic Service Manual (ESM) for Removal and Installation instructions. See this bulletin for further detail.
NTB10079 - SB Nissan; MIL "ON" with DTC P0128 (Thermostat Function) Stored
* IF YOU CONFIRM The MIL is "ON" with P0128 (Thermostat Function) stored. ACTIONS 1. Check to see if an aftermarket remote starter system is installed. - Remote starter systems may cause the MIL to illuminate and DTC P0128 to store. 2. If a remote starter system is installed, remove/disconnect it before performing diagnostic procedures on the vehicle. See this bulletin for further detail.
NTB10077 - SB Nissan; ABS Self Check Noise
* SERVICE INFORMATION If you identify: - Clicking, knocking, clunking, buzzing, or thumping noise coming from the engine compartment area; and - The noise occurs only once during the first few seconds of driving at approximately 16 MPH; and - The noise occurs only once per ignition cycle (ignition OFF > ON) and does not occur again until the ignition is cycled. NOTE: The noise may be louder after the vehicle has not been operated for a prolonged period of time. The above condition is normal and does not need repair. See this bulletin for further detail.
NTB10074 - SB 2008 Rogue; Noise When Turning Steering Wheel
* IF YOU CONFIRM There is a squeaking or rubbing noise when the steering wheel is turned, and the noise can be isolated to the steering rack pinion shaft column seal (dash seal). ACTION Replace the column seal (dash seal) See this bulletin for further detail.
NTB10066 - SB Nissan; CAN Communication Codes - Diagnostic Tips & Guidelines -
* SERVICE INFORMATION Related to communication codes U1000, U1001, U1002, U1010: - Always diagnose the communication codes first. - When a module reports a U1000 code, it is typically operating normally; however, there is a communication error external to that module on the CAN network. - U1000 indicates an error. V-CAN diagram or CAN Diag Support Monitor provides data to determine the location of the error. See this bulletin for more information.
NTB10061 - SB Nissan; Xenon Headlamp Service
* IF YOU CONFIRM A xenon headlamp is not functioning because of an issue inside the headlamp assembly (an internal issue), ACTION Refer to the appropriate Service Manual, follow the diagnostic and repair information for xenon headlamps. NOTE: Do not replace the entire xenon headlamp assembly when only a bulb or HID control unit is needed to solve the incident, if one should occur. See this bulletin for further detail.
NTB10059 - SB cube and Rogue; Remote Keyless Entry Keyfob Replacement
* SERVICE INFORMATION The remote piece of a Remote Keyless Entry System (RKES) keyfob is now available separately as a service part for the Applied Vehicles. If the remote piece needs to be replaced for any reason: - Replace only the remote piece and the screw with the ones listed in the Parts Information section. NOTE: Do not replace the entire RKES keyfob if only the remote piece is needed. See this bulletin for more detail.
NTB10048 - SB Nissan; Signal Tech II Diagnostic Tool
SERVICE INFORMATION If service is required on a vehicles Tire Pressure Monitor System (TPMS), remote keyless entry, or intelligent key, the Signal Tech II (special tool J-50190) can be used for diagnostics. See this bulletin for further detail.
NTB10038 - SB Nissan; Testing JIS-Type & CCA-Type Batteries
SERVICE INFORMATION Nissan vehicles equipped with standard lead/acid batteries use one of two different types with unique battery rating specifications: JIS & CCA. JIS = Japan Industrial Standard, used for Japan produced batteries CCA = Cold Cranking Amps, standard for North American produced batteries IMPORTANT: - JIS batteries have different testing specifications than CCA batteries. - If you must use the GR8 Battery Tester in a mode other than MODEL mode, JIS Mode MUST ALWAYS BE USED for JIS batteries otherwise an incorrect result will occur. NEVER test a JIS battery using the CCA test in the GR8; the test software in the GR8 is different for JIS and CCA modes. ANY CCA value you may have for a JIS-type battery is inaccurate for testing purposes. See this bulletin for further details.
NTB10029 - SB Murano/Rogue; Grinding/Knocking Noise From Rear When Turning
IF YOU CONFIRM There is a grinding or knocking noise or vibration from the rear of the vehicle: - when making wide turns - on dry roads - at low speeds (under 20 MPH). ACTION Remove the Rear Propeller Shaft and test drive the vehicle: If the noise/vibration DOES NOT stop: This bulletin DOES NOT APPLY. Refer to ASIST for further diagnostic assistance. If the noise/vibration DOES stop: Replace the Electrical Coupling Assy. (CPLG ASSY-ELEC) with the one from the Parts Information section of this bulletin. Refer to the appropriate section in the Electronic Service Manual for removal and installation. DO NOT replace the entire Rear Final Drive assembly for this incident, if it should occur.
NTB10027 - SB 2008-2010 Rogue ECM Reprogram Interruption Recovery
IF YOU CONFIRM While performing ECM (Engine Control Module) reprogramming, the reprogramming stops (is interrupted) before it is 100% complete. ACTION Perform the reprogramming recovery procedure in this bulletin. See this bulletin for further detail.
NTB10019 - SB 2008 - 2010 Rogue; Rubbing Noise From Spiral Cable
IF YOU CONFIRM A rubbing noise coming from the spiral cable when turning the steering wheel. ACTION Replace the spiral cable locating cap. See this bulletin for further detail.
NTB10018 - SB 2008 - 2010 Rogue; DTC P0444 Stored
IF YOU CONFIRM DTC P0444 (EVAP Canister Purge Volume Control Solenoid Valve Circuit Open) is stored, ACTIONS 1. Check for a broken wire at the Canister Purge Volume Control Solenoid Valve connector. 2. If there is a broken wire at the connector,install the Harness Service Kit listed in the Parts Information. See this bulletin for further detail.
NTB10009 - SB Nissan; Removal Procedure for Seized Exhaust Sensor
SERVICE INFORMATION If an exhaust sensor is seized in the exhaust manifold/catalyst/front tube, perform the procedure described in this bulletin to remove the sensor and prevent unnecessary replacement of the exhaust manifold/catalyst/front tube. Inmost cases this procedure is successful. This is because the threads of the exhaust sensors are made of a softer material than the part they thread into on the exhaust manifold/catalyst/front tube. NOTE: The replacement of exhaust manifolds/catalyst s/front tubes for stripped exhaust sensor threads may not be considered a warrantable expense. See this bulletin for further detail.
NTB10002 - SB Nissan; Drive Belt System Noise Diagnosis
IF YOU CONFIRM There is noise coming from the drive belt(s), or drive belt pulley(s), ACTION Use the flow chart in this bulletin to help diagnose and identify the source / cause of the noise.
NTB09148 - SB Altima/Rogue/Sentra; MIL "ON" w/DTC P0840/P0845/P0744/P1777
* IF YOU CONFIRM Any of the following DTCs are stored in the TCM: - P0840 - P0845 - P0744 - P1777 ACTIONS Replace the Control Valve Assembly with the part listed in the Parts Information section of this bulletin. Reference SECTION TM, CONTROL VALVE Removal and Inspection in the appropriate ESM for directions. Erase the EEP ROM calibration data in the TCM and allow it to recalibrate. Reference NTB08-064; CVT AND 5 SPEED A/T INITIALIZATION INFORMATION for directions.
NTB09141 - SB Nissan; Remanufactured Engine Lubrication Upon Initial Start Up
* SERVICE INFORMATION During remanufactured engine storage, upper engine lubrication may dissipate/disperse. Camshaft scoring or seizure may occur at initial start up unless the procedure described within this bulletin is followed. See this bulletin for further detail.
NTB09140 - SB Nissan; CVT Oil Leak Diagnosis Using Florescent Dye
SERVICE INFORMATION If you have a CVT that appears to have oil seepage or a leak on the transmission, follow the steps in this bulleitn to assist in a correct diagnosis.
NTB09139 - SB Rogue; Sunroof Will Not Close Completely
IF YOU CONFIRM: The sunroof will not close due to interference by the wind deflector. ACTION: Replace the wind deflector with the one listed in PARTS INFORMATION on Page 2. For part replacement, refer to SERVICE PROCEDURE on Page 2. See this bulletin for further detail.
NTB09136 - SB 2005 and Later; ECM VIN Registration
SERVICE INFORMATION The Applied Vehicles in this bulletin must have the correct Vehicle Identification Number (VIN) registered in the Engine Control Module (ECM). The VIN registration process must be performed under the following conditions. - When installing a new ECM - If, during vehicle service, the VIN registration inside the ECM is found to be missing or incorrect. When needed, use the Service Procedure in this bulletin to perform ECM VIN registration. See this bulletin for further detail.
NTB09131 - SB Certification Label and VIN Plate Replacement
SERVICE INFORMATION Because of collision damage or other vehicle repair, a replacement "Certification Label" or "VIN Plate / Label" may be needed. These items may be available from Nissan by request if certain criteria are met. This bulletin lists the criteria and provides an application form for such replacements. See this bulletin for further detail.
NTB09129 - SB Vent Control Valve Replacement
SERVICE INFORMATION When replacing the EVAP canister vent control valve for any reason: -Use the one listed in the PARTS INFORMATION section of this bulletin on Page 2. -For vent control valve replacement procedure, refer to the appropriate section ofthe Electronic Service Manual (ESM) if needed. -When installing the new valve, do not add any lube to its o-ring. -For Frontier (D40 series) only: install the protector listed in PARTS INFORMATION. --For protector installation, see the SERVICE PROCED URE section of this bulletin starting on Page 3. -Make sure to use the "new style" valve listed in PARTS INFORMATION. See this bulletin for further detail
NTB09126 - CP 2008 - 2009 Rogue; Transmission Rattle Noise - Voluntary Service Campaign
Some model year 2008 and 2009 Rogue vehicles may have a rattle noise from the transmission at low speeds. Nissan is conducting this Voluntary Service Campaign to remedy this potential condition. This campaign will entail reprogramming the Transmission and Engine Control Modules (TCM and ECM) and, for 2008 models, checking the transmission fluid level at no charge for parts or labor.
NTB09125 - CP 2008 - 2009 Rogue; Front Door Handles - Voluntary Service Campaign
In certain 2008 and 2009 Nissan Rogue vehicles, to assure customer satisfaction, Nissan is conducting a voluntary service campaign to install seals to the door latch assembly and apply special grease to the door cable ends to prevent freezing under certain conditions. See this bulletin for further details.
NTB09123 - SB Power Socket Remover Tool J-42059
SERVICE INFORMATION If the power socket needs to be removed or replaced for any reason: -Refer to the SERVICE PROCEDURE section of this bulletin on Page 2. -Use Power Socket Tool J-42059. See this bulletin for further detail.
NTB09112 - CP 2008 - 2009 Rogue; Steering Gear - Voluntary Safety Recall Campaign
On some 2008 - 2009 Rogue vehicles, the steering gear housing cover screw may have been manufactured incorrectly. Over time, the screw may gradually loosen, and could possibly fall out. To correct this issue, Nissan is conducting this Voluntary Safety Recall Campaign to confirm the steering gear housing cover screw is tight, and also install a "lock plate" to prevent the screw from possibly coming out of the steering gear housing. See this bulletin for further detail.
NHTSA Recall Notice:
Vehicle Make / Model: NISSAN / ROGUE
Model Year(s): 2008-2009
NHTSA CAMPAIGN ID Number: 09V411000
Summary:
NISSAN IS RECALLING CERTAIN MODEL YEAR 2008-2009 ROGUE VEHICLES. A SCREW IN THE STEERING GEAR HOUSING COVER MAY LOOSEN OVER TIME AND COULD FALL OUT. AS IT LOOSENS, THE STEERING RESPONSE OF THE VEHICLE MAY BE COMPROMISED BUT THE DRIVER WILL RETAIN STEERING CONTROL.
Consequence:THE SCREW MAY EVENTUALLY COME OUT OF THE STEERING GEAR COVER. IF LARGE STEERING INPUTS ARE MADE WITH THE COVER SCREW MISSING THE PINION SHAFT MAY COME OUT OF THE STEERING GEAR RESULTING IN A COMPLETE LOSS OF STEERING CONTROL AND INCREASING THE RISK OF A CRASH.
Remedy:DEALERS WILL INSPECT WHETHER THE STEERING GEAR COVER SCREW IS LOOSE AND WILL BE RETIGHTENED TO THE PROPER SPECIFICATION. DEALERS WILL ALSO INSTALL A COVER PLATE TO PREVENT THE SCREW FROM POSSIBLY COMING OUT OF THE STEERING GEAR. THIS SERVICE WILL BE PERFORMED FREE OF CHARGE. THE RECALL IS EXPECTED TO BEGIN DURING NOVEMBER 2009. OWNERS MAY CONTACT NISSAN AT 1-800-647-7261.
Notes:OWNERS MAY ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY 1-800-424-9153), OR GO TO HTTP://WWW.SAFERCAR.GOV .
Full Recall Notice here: http://www-odi.nhtsa.dot.gov/c...lDown
Transport Canada Recall # 2009303
Recall Date: 2009/10/19
Notification Type: Safety
MfrSystem: Steering
Manufacturer Recall Number:
Units Affected: 23,323
Category: SUV
Recall Details:On certain vehicles, the steering gear housing cover screw may have been manufactured out of specification and the axial tension between the screw and gear housing may deteriorate over time. This could allow the screw to gradually loosen, which will cause the steering wheel to exhibit noticeable looseness from the steering assembly. If the vehicle continues to be driven in this condition, the screw may eventually come out of the steering gear housing. If large steering inputs are made with the cover screw missing, the pinion shaft may come out of the steering gear. This may result in a loss of steering control, which could lead to a crash causing property damage, personal injury or death. Correction: Dealers will inspect whether the steering gear cover screw is loose. If it is loose, it will be retightened to the proper specification. In addition, the dealer will install a cover plate to prevent the screw from possibly coming out of the steering gear.
Make: NISSAN
Model: ROGUE
Model Year(s) Affected: 2008 2009
NTB09110 - CP Rogue, Murano cube; Wheel Valve Stem Nut - Service Campaign
Some Model Year 2008 - 2009 Rogue, 2009 Murano, and 2009 cube® vehicles may have been built with Tire Pressure Monitor System (TPMS) transmitter nuts that were not manufactured to specification. Over time, these nuts may corrode and potentially crack, especially in areas where heavy concentrations of road salt are used. For those vehicles located at dealerships or registered to owners in States that do not use a heavy concentration of road salt, Nissan is conducting this Voluntary Service Campaign. Theservice campaign repair entails replacement of the TPMS transmitter nuts at no charge for parts or labor. See this bulletin for further detail.
NTB09107 - CP Rogue, Murano, cube; Wheel Valve Stem Nut - Recall Campaign
Some Model Year 2008 - 2009 Rogue, 2009 Murano, and 2009 cube® vehicles may have been built with Tire Pressure Monitor System (TPMS) transmitter nuts that were not manufactured to specification. Over time, these nuts may corrode and potentially crack, especially in areas where heavy concentrations of road salt are used. To remedy this potential condition, Nissan is conducting this Voluntary Safety Recall Campaign for vehicles in dealer inventory located in "Salt States" and for customer vehicles registered in "Salt States" at the time of the launch of this campaign. The campaign repair will entail replacement of the TPMS transmitter nuts at no charge for parts of labor. See this bulletin for further detail.
Vehicle make / model model year(s):
Infiniti / M35: 2008-2010
Infiniti / M45 2008-2010
Nissan / Cube 2009
Nissan / Murano 2009
Nissan / Rogue 2008
NHTSA campaign id number: 09v393000
Summary: Nissan is recalling certain model year 2008-2010 vehicles originally sold in or currently registered in the states of Connecticut, Delaware, Iowa, Illinois, Indiana, Massachusetts, Maine, Maryland, Michigan, Minnesota, Missouri, New Hampshire, New Jersey, New York, Ohio, Pennsylvania, Rhode Island, Vermont, Washington D.C., West Virginia and Wisconsin. The material in the nut used to secure the sensor-transmitter of the tire pressure monitoring system (TPMS) may corrode and potentially crack in areas with heavy concentrations of road salt. If this occurs, the nut may come out of the sensor-transmitter and the TPMS lamp will illuminate.
Consequence: If the TPMS lamp is disregarded and the vehicle continues to be driven in this condition, the tire will quickly lose air pressure at a consistent rate resulting in a flat tire increasing the risk of a crash.
Remedy: The dealer will replace the TPMS nut with a new, more robust nut. This service will be performed free of charge. The recall is expected to begin on or before November 9, 2009. Owners may contact Nissan at 1-800-647-7261 and Infiniti at 1-800-662-6200 .
Notes: Owners may also contact the National Highway Traffic Safety Administration's vehicle safety hotline at 1-888-327-4236 (tty 1-800-424-9153 ), or go to http://www.safercar.gov Read the full recall along with additional info at NHTSA:http://nhthqnwws112.odi.nhtsa....4.pdf
Transport Canada Recall # 2009283
Recall Date: 2009/10/02
Notification Type: Safety TC
System: Other
Units Affected: 18,362
Category: SUV
Recall Details: On certain vehicles, material in the nut used to secure the sensor-transmitter of the Tire Pressure Monitoring System (TPMS) may corrode and crack in areas with heavy concentrations of road salt. If this occurs, the nut may come out of the TPMS sensor-transmitter causing a rapid loss of tire air pressure. This could adversely affect vehicle control and cause a crash resulting in property damage, personal injury or death. Correction: Dealers will replace the TPMS nut with a revised version.
Make Model Model Year(s) Affected:
INFINITI M35 2008 2009 2010
INFINITI M45 2008 2009 2010
NISSAN CUBE 2009
NISSAN MURANO 2009
NISSAN ROGUE 2008 2009
Read the full recall here: http://wwwapps.tc.gc.ca/saf-se...pg=-1
NTB09101 - SB Nissan; TPMS Warning Light ON / Flashing
* IF YOU CONFIRM The TPMS warning light is illuminated steady or flashing. ACTIONS STEP 1: Turn the ignition OFF and then ON (engine not running). >If the TPMS warning lamp is illuminated steady (not flashing), the TPMS is operating normally and has detected low tire pressure in one of the tires. Go to step 2. >If the TPMS warning lamp is flashing for approximately one minute, there is a TPMS system malfunction. Do not go to step 2. Instead, check the DTC and refer to the Service Manual for r epair instructions. STEP 2: Leave the ignition ON (engine not running) and set the tire pressure to the recommended pressure. See this bulletin for further information.
NTB09099 - SB Nissan; A/C System O-ring Seal Leaks
* IF YOU CONFIRM A refrigerant leak at a refrigerant pipe/hose joint location, ACTIONS 1. Inspect the metal surfaces of the pipe/hose joint for damage or contamination. NOTE: Do not replace a refrigerant pipe, hose, or other A/C component if an o-ring seal will solve the leak incident, if it should occur. 2. If no damage is found to the joint metal surfaces, replace the O-ring seal. See this bulletin for further detail.
NTB09097 - SB 2008-2009 Rogue; Sunroof Does Not Operate Properly
* IF YOU CONFIRM Sunroof auto operation will not work or sunroof does not operate properly: - When the battery has been disconnected or discharged - When the sunroof motor has been disconnected from power - When the sunroof motor has been changed ACTION Perform the initialization procedure described in this bulletin. See this bulletin for further detail.
NTB09093 - SB 2008-2009 Rogue; Brake Judder
* IF YOU CONFIRM: While braking, especially at highway speeds: the steering wheel shakes AND / OR the body vibrates AND / OR the brake pedal pulsates (also known as "Brake Judder"). ACTIONS: 1. Replace both Front Brake Splash Guard Assemblies (Backing Plates) with the part numbers (P/Ns) listed in the PARTS INFORMATION section below. 2. Inspect the front brake rotors. Determine if resurfacing is possible, or if replacement is necessary. 3. Inspect the front brake pads and front brake caliper hardware. Replace each, as needed only. See this bulletin for further detail.
NTB09081 - SB Windshield Cracking
* The Purpose of this bulletin is to give Nissan dealers guidelines to help determine if windshield breakage is covered under warranty or is the customer's responsibility. Nissan North America (NNA) is not responsible for damage to glass that is a result of objects striking or scratching the glass. However, NNA is responsible for manufacturing issues such as distorted glass and cracks that are due to improper installation or damage to the glass during vehicle assembly. NNA typically does not find an y type of cracks in the windshield due to stress in vehicles with over 5000 miles. See this bulletin for further detail.
NTB09063 - SB Bluetooth Phone System; Initial Diagnosis
* SERVICE INFORMATION If a vehicle comes to the dealer with a Bluetooth® phone system related concern, use this bulletin for initial diagnosis. This bulletin will help reduce unnecessary diagnosis and parts replacement. Refer to the SERVICE PROCEDUREsection below, and QUICK REFERENCE on Page 3. See this bulletin for further detail.
NTB09056 - SB Nissan; Accessory Wheel Locks Installation and Removal
* SERVICE INFORMATION Always use hand tools when installing or removing accessory wheel lock nuts. WARNING: Do not use power tools to install or remove accessory wheel lock nuts. Use of an impact wrench or other power tool may cause permanent damage to the wheel lock nut and/or key. See this bulletin for further detail.
NTB09052 - SB Nissan; CONSULT-III TCM Reprogramming Procedure
* SERVICE INFORMATION A complete step-by-step General Procedure for C-III TCM Reprogramming is now available by hyperlink in this bulletin. This General Procedure is also available via hyperlink from specific C-III symptom-based Technical Service Bulletins in ASIST. See this bulletin for further detail.
NTB09047 - SB Nissan; Portable Navigation Unit Issues
* SERVICE INFORMATION If there is any incident with the function of the Nuvi 750 Portable Navigation Unit BEFORE ATTEMPTING ANY REPAIRS: Perform a System Reset of the Unit by sliding the "Power Key" to the left and hold for eight (8) seconds, then return it to the normal position. See this bulletin for further details.
NTB09044 - SB Nissan; MIL ON With P0840/P0845 And P0710
IF YOU CONFIRM: An applied vehicle has CVT Fluid that is discolored and / or has unusual odor. AND The MIL is ‘ON’ with DTCs P0840 and / or P0845 stored in CONSULT III / ENGINE and / or TRANSMISSION. OR The MIL is ‘ON’ and P0710 is stored in CONSULT III / ENGINE and / or TRANSMISSION. P0710 may be stored with P0840 and / or P0845. NOTE: The vehicle may also have reduced performance during acceleration. ACTIONS: Check the vehicle’s Transmission Control Module (TCM) part number (P/N). If the TCM P/N is listed in the Current TCM P/N list on page 11, the service procedure in this bulletin applies. If the TCM P/N is not on the Current TCM P/N list, this bulletin does not apply. Refer to the appropriate Electronic Service Manual (ESM) for further diagnosis. See this bulletin for further detail.
NTB09040 - SB Nissan; New Blue Nissan Long Life Antifreeze/Coolant
SERVICE INFORMATION Beginning in calendar year 2009 some Nissan vehicles are filled at the factory with a NEW Genuine Nissan Long Life Antifreeze/Coolant (LLC) that is blue in color. See this bulletin for further detail.
NTB09036 - SB Nissan; IPDM Service
* SERVICE INFORMATION The Intelligent Power Distribution Module (IPDM) is ONLY serviceable as an assembly. The ONLY serviceable parts of an IPDM are the fuses. See this bulletin for further detail.
NTB09030 - SB Nissan; ECU Damage Can Result From Improper Battery Connection
SERVICE INFORMATION: The vehicle 12 volt battery is an important part of the vehicle electrical system and is required to stay connected when the engine is running. To prevent damage to vehicle electronic components follow the instructions / cautions in this bulletin. IMPORTANT: Damage to electronic components (ECM, TCM, BCM, etc) due to improper battery connection will not be covered under warranty.
NTB09029 - SB Nissan; CONSULT-III ECM Reprogramming Procedure
* SERVICE INFORMATION A complete step-by-step General Procedure for C-III ECM Reprogramming is now available by hyperlink in this bulletin. This General Procedure is also available via hyperlink from specific C-III symptom-based Technical Service Bulletins in ASIST. See this bulletin for further detail.
NTB09022 - SB Nissan; Battery Storage and Maintenance - Vehicles in Dealer Inventory
SERVICE INFORMATION: Proper storage and maintenance of vehicle batteries is the dealer's responsibility and an important part of insuring good battery operating life. Vehicles being stored at the dealer should have their batteries State Of Charge(SOC) routinely checked. See this bulletin for further detail.
NTB09020 - SB Nissan; EVAP Leak DTC Diagnosis
SERVICE INFORMATION: If one or more DTCs listed below related to EVAP system leaks is found stored in Self Diagnosis, use the REPAIR FLOW CHART on page 2. Use the EVAP system diagram for reference on page 3. DTCs: P0440, P0442, P0455, P0456, P1440, and P1456. See this bulletin for further detail.
NTB09009 - SB 08-09 Rogue; Fuel Gauge Doesn't Read Full/Slow Respond
IF YOU CONFIRM • Fuel level gauge does not read full when tank is full. OR • Fuel level gauge is inaccurate or reads erratically. ACTION • For 2WD models, replace the fuel sender unit only. • For AWD models, replace the fuel sender unit and sub-sender unit. See this bulletin for further detail.
NTB09006 - SB Nissan; Diagnosis Procedure for MIL On DTC P0603 ECM Power Supply
* SERVICE INFORMATION If you have a vehicle with the MIL "ON" that has a DTC P0603 stored in the ECM: Perform the diagnostic steps in this bulletin FIRST. This DTC may have been stored due to a series of previous low battery voltage, dead battery orbattery terminal disconnections. DO NOT perform any other diagnostic procedures or repairs for this code until you have performed the ones in this bulletin. See the Service Procedure in this bulletin for further detail.
NTB08110 - SB Nissan; Essential Tool:J-41425 Tubing Repair Kit
If you find that a section of heater coolant or A/C refrigerant hard tubing needs to be replaced for any reason, the J-41425-NIS Tubing Repair Kit is now available. • This Kit will allow you, using the included tubing cutter, to cut out the damaged section and using the connectors and tools in the Kit splice in a replacement section from the matching service part. • This method of tubing repair, rather than tubing replacement, is more convienent in cases where installing the entire service partwould require major disassembly of the vehicle. See this bulletin for further details.
NTB08108 - SB Nissan; I-Key Registration Caution
CAUTION: Before starting any I-Key registration procedures: • #1: The vehicle battery voltage must be at and remain above 12.4 volts during the procedure. THEN • #2: The transmission selector lever must be in the Park position for A/T & CVT vehicles or in the Neutral position for Manual transmission vehicles. THEN • #3: "Wiggle" the steering wheel back and forth to make sure the steering lock is not bound-up on the column, and then release the Steering Lock. THEN • #4: Proceed with I-Key registration. If these steps are not followed before I-Key registration is started electronic damage to the Steering Lock may occur.
NTB08107 - SB Nissan; Intelligent Key Inoperative
IF YOU CONFIRM The Intelligent Key is not functioning for any reason, ACTIONS 1. Check the outside of the Key for physical damage. 2. Check for water intrusion inside the Key. 3. Refer to the Service Manual for additional Intelligent Key diagnostic and repair information. See this bulletin for further detail.
NTB08102 - SB Nissan; DTC P0456 Diagnostic Information
On-Board Diagnosis of Diagnostic Trouble Code (DTC) P0456 for the Applied Vehicles is sometimes performed when the engine is not running. • This is known as Engine Off Natural Vacuum (EONV) Diagnosis • The Freeze Frame Data shown in this bulletin is NORMAL when DTC P0456 is stored during EONV Diagnosis.
NTB08097 - SB Nissan; Alignment and Road Crown
Customers may report that their vehicle "pulls" or the steering wheel is "off-center". This bulletin discusses these subjects and provides diagnostic and repair information. See this bulletin for further detail.
NTB08095 - CP 2007-09; Pass. Air Bag Occupant Class. System (OCS) Voluntary Recall Campaign
Nissan is conducting a Voluntary Recall Campaign to inspect the Occupant classification System (OCS) Varistor located in the front passenger seat cushion. A special tool will be used for the inspection. If the inspection results are OK, no further action is necessary. If the special tool indicates an OCS Varistor issue, the seat cushion assembly will be replaced. We anticipate that less than 1% of the affected vehicles will require seat cushion replacement. See this bulletin for further detail.
NTB08064 - SB CVT and FWD 5 Speed A/T Initialization Information
When installing a TCM (Transmission Control Module), CVT or 5 Speed A/T on an applied vehicle, initialize the TCM under the following conditions: See this bulletin for further detail.
NTB08055 - SB Nissan; SRS Precautions During Service
Information necessary to service the Supplemental Restraint System (SRS) safely isincluded in the “RESTRAINTS” section of the Electronic Service Manual (ESM) for each vehicle.IMPORTANT: Turn the ignition switch OFF; disconnect both battery terminals; and wait atleast 3 minutes before performing any service on the SRS.
NTB08049 - SB Nissan; Special Automatic Transmission Fluid Requirement
If Warranty repairs are being done on a transmission listed in the chart below, the listed fluid must be used. A claim to Nissan for warranty, service contract, or goodwill repairs to the transmissions listed below may be denied if Genuine Nissan ATF/CVT Fluid is not used as specified by the part # in this bulletin. If Customer Pay service or repair of the transmissions listed below is done, the fluid type listed in the chart below must be used. Nissan recommends the Genuine Nissan ATF/CVT fluid part # listed in this bulletin be used.
NTB08037 - SB 08 Rogue; MIL Light On DTC P0463
IF YOU CONFIRM DTC P0463 (Fuel Level Sensor Circuit High Input) is stored in the ECM and there are no other vehicle driveability symptoms, ACTIONS: Confirm this bulletin applies. Check and compare your Current ECM Part Number to Table A on page 3. If that part number does not match one in Table A, this bulletin does not apply. Go back to ASIST for further diagnostic and repair information. See this bulletin for further detail.
NTB08033 - SB Nissan: Tire Pressure Information
SERVICE INFORMATION The air pressure inside a tire can change due to several factors, such as: ambient temperature change, tire temperature change due to driving conditions, altitude change, and natural pressure loss over time. It is important that tire pressure be checked often to keep it at the specified setting, especially after seasonal temperature changes. Any of the above factors can contribute to low tire pressure. Low tire pressure can cause a Tire Pressure Monitor System (TPMS) to turn ON the Low Tire Pressure Warning Light (if equipped). However, this does not mean that the TPMS is not operating as designed. See this bulletin for further detail.
NTB08032 - SB Nissan; TPMS Sensor Seal Leak
SERVICE INFORMATION When repairing an air leak at a TPMS (Tire Pressure Monitor System) sensor seal, a seal is now available separately. Do not replace the entire sensor when only a seal is needed. See this bulletin for further detail.
NTB08031 - SB 08 Rogue; Creaking Noise from Console Finisher
IF YOU CONFIRM There is a creaking noise coming from the console finisher assembly when making turns. ACTIONS Remove the console finisher assembly. Put tape from the squeak and rattle kit on the 9 ribs located on the upper half of the console finisher assembly. See Figure 1. See this bulletin for further detail.
NTB08020 - CP Nissan; Hitch Mounted Bicycle Rack - Voluntary Recall Campaign
Thule, a bicycle rack manufacturer that supplies bicycle racks to Nissan dealers, has decided that a defect that relates to motor vehicle safety exists in certain hitch mounted bicycle racks (Nissan part number 999R5-AR000). There is a pinch point in the bicycle rack that can potentially cause a severe hand or finger injury when moving the bicycle rack bracket to its down position. To remedy this potential condition, a retrofit kit is available free of charge to repair the bicycle rack. The kit includes a bumper, a warning sticker and written instructions regarding the installation of both.
See Thuleracks.com for more detail: http://www.thuleracks.com/recall.asp
NTB08008 - SB Nissan; Intelligent Key / NATS Key Registration Procedures
The Service Procedures for the following will no longer be in Technical Service Bulletins: - NATS Key registration. - Intelligent Key registration. - Steering Look Unit ID Registration These Procedures are now only available in the CONSULT-III Operations Manual. See this bulletin for further detail.
NTB06079 - SB Nissan; DTC for Variable Valve Timing Control Function
IF YOU CONFIRM The MIL is on with any of the following DTCs stored: P0011, P0014, P0021, P0024, P1110, P1135, ACTION Do Not replace the variable valve timing Solenoid Valve or the Sprocket(s) without performing the complete diagnostics indicated in the EC section of the Service Manual. The first step in the complete diagnostic is to make sure the engine oil is at the operating level and oil pressure is normal when measured with a gauge at the pressure switch port. See this bulletin for further detail.
NTB06065 - SB Nissan; Power Window Auto Up Initialization
IF YOU CONFIRM A power window "Auto Up" will not work, ACTION Perform the following initialization procedure: 1. Turn the Ignition switch ON. 2. Open the window-all the way DOWN. 3. Pull all the way UP on the switch and hold (close the window). Continue holding the switch all the way UP for 4 seconds after the window is closed. 4. Confirm the window is now operating correctly. See this bulletin for further detail.
NTB04049 - SB Nissan; Trailer Light Wiring
SERVICE INFORMATION NOTE: This bulletin provides information to be shared with all affected customers. -This TSB contains the appropriate hookup points for connecting a trailer lighting wiring harness to the towing vehicle electrical system. -The wiring diagrams contained in this bulletin are for Nissan vehicles that do not have a Genuine Nissan accessory towing kit (with wiring) available. See this bulletin for further detail.
NTB03074 - SB Nissan; Exterior Lamp Fogging
SERVICE INFORMATION Occasionally customers may complain about water in the external lamps. - Customers may think that this condition is a defect in the external lamp. - However in many cases some amount of moisture is considered normal. The information within this bulletin is provided to help you in determining if a complaint for water/condensation in the external lamps is normal or not. See this bulletin for further details.
NTB00056 - SB Nissan; 1988 and Later Nissan Vehicles Automatic Transmission Oil Cooler Cleaning
Whenever an automatic transmission (A/T) is repaired, overhauled, or replaced, the A/T oil cooler mounted in the radiator must be inspected and cleaned. Metal debris and friction material, if present, can become trapped in the A/T oil cooler and may build up as transmission fluid enters the Cooler Inlet. This debris can contaminate the newly serviced transmission. In severe cases this debris can block or restrict the flow of transmission fluid/oil. In either case, failure of the newly serviced A/T may result.
NTB00042 - SB Nissan; Modifications to and/or Tampering with Supplemental Side Air Bag
This bulletin was amended on March 6, 2007 Modifications to and/or tampering of any kind with Supplemental Side Air Bags and/or Nissan Advanced Air Bag System could affect the deployment or performance of the air bag system and could result in serious personal injury. Modifications and/or tampering include changes to the front seat assembly such as adding or changing trim materials from the factory equipped condition (i.e., replacing the seat trim with non-factory materials; adding leather/cloth seat covers, seat pads, or seat storage pouches, etc.) around or over the side air bag system and/or on the passenger seat cushion. See this bulletin for further detail.
NTB00033 - SB Nissan; Brake Noise/Judder/Pedal Feel Diagnosis And Repair
SERVICE INFORMATION This bulletin is to assist you in responding to customer questions about brake operation, and provides diagnostic and repair information for each item listed, if any should occur. Most brake incidents fall into the following categories: a. Brake Noise: A squeak, squeal, clunk, or groan that occurs when the brakes are applied or released. b. Brake Judder: A vibration that can be felt in the vehicle, steering wheel, or brake pedal when the brakes are applied. c. Pedal Feel:The effort needed to operate the brakes is too high or too low. SERVICE PROCEDURE 1. Verify the condition by road testing the vehicle with the customer. 2. Determine the specific brake incident based on the description in the Service Information ab ove. 3. Follow the appropriate repair procedure(s), listed on the following pages, for your specific incident. See this bulletin for further details.
NTB99060 - SB All Nissan; Paint Swell/Stain/Spot Under Paint Guard Film
In an effort to protect the paint finish, Paint Guard Film (PGF) is applied on many new Nissan vehicles. Paint Guard Film (PGF) is a temporary white plastic protective film that is applied by the factory to the horizontal painted surfaces of the vehicle. The PGF protects the paint finish during vehicle handling, transportation and storage from harmful elements such as acid rain, iron particles, bird droppings, tree sap and other environmental contaminants. See this bulletin for further detail.
NTB99020 - SB All Nissan; Limitations on Flat Towing of Nissan Vehicles
This Bulletin contains important guidelines and limitations concerning towing of Nissan vehicles with all four wheels on the ground ("flat towing"). See this Bulletin for further detail.
Nissan Original Equipment or Genuine Accessory Alloy wheels, along with their finish coating (clear, chrome, titanium, etc.), are specifically developed to achieve Nissan design and performance standards. These Original Equipment or Genuine Accessory wheels are subjected to testing to ensure they meet Nissan's standards. Nissan Original Equipment Alloy or Genuine Accessory wheels subjected to aftermarket chroming may no longer continue to meet these standards and may be seriously damaged. Therefore, Nissan most strongly discourages, and recommends that these wheels NEVER be subjected to, aftermarket chroming. See this bulletin for further detail.
