Hey all, just joined this forum club after I've used this site numerous times to work and fix things on my Pathy.
Currently, I've got 137k miles on the Pathfinder... and she's a 1993! Honestly didn't believe it, but the Carfax showed no odometer rollback so I knew that it was legitimate when I traded for it this past April. I'm now the 3rd owner. First one was a nurse and I'm certain to believe that she took really good care of it. However the kid before me beat it up badly (had a transmission replaced, also tore the driver door off in an incident with a parking brake
but overall she still runs great!
I take great care of my vehicles and this one is no exception. I've put the most work into it (My first car was a 94 Chevy Corsica, and other than oil changes, I replaced a thermostat. Easy. 2nd Car was a 99 Chrysler Concorde. Did the belts and a CV boot. All of that before the engine blew... which blew again after a new engine was put in. Third car was my last one, a 97 Mazda 626.. Loved it. First 5-Speed. Other than oil changes, a CV axle replacement, and occasionally plugging up an exhaust leak, It was pretty maintenance free!)
My Pathy has been getting a lot of my attention (and money) since April... Day after I got it, the timing belt skipped (ended up being a bent washer on the crankshaft) but it was easily fixed after a 2 day garage fix. Done the easy tuneup (Ignition Coil, Spark plugs, Distributor Cap and Rotor). When the timing belt went, I wasn't sure if by putting a new one on that it would work, and being that I was short on money, I didn't do the Water pump... but I'm thinking about doing that before next Spring. Beyond the oil changes (I use synthetic Mobil 1 oil, just because I feel that it helps along with a good oil filter (varies)) I've also done the exhaust manifold replacement with the studs as it was leaking and giving me a nice "tree frog" sound when I'd take it out of gear. I also noticed the valve cover gasket is leaking a little so I'll probably replace that in either October or over Thanksgiving Break. New headlights, as well as replacing both bumpers (they were the chrome ones originally and were rusting badly) Also done the diff fluid, trans fluid and transfer case fluid.
I believe I've got a solid Pathy. I primarily use it for transportation between school and home (150 mile trip) and also for Storm Chasing. Love it, and hope it'll give me quite a bit more years!
