hp600jake »
https://forums.nicoclub.com/hp600jake-u126772.html
Mon Feb 23, 2009 6:48 pm
Hey everyone. I am new at the forums site. But I have been having a problem with CD changer for years. Finally, i decided I have nothing to lose to tear it apart and look inside. First, I found 3 CDs that it would not eject, and one was jammed underneith the eye. After removing the CDs, and not fixing the problem, I took a 9 volt battery to all of the motors to make sure they were working fine. They all worked, however after checking the one motor that operates, I realized that the spiral pin gear that moves the eye has a crappy plastic gear on the end of it that spins it. With the motor spinning, i noticed this plastic gear was spinning but not spinning the pin gear for the eye. I am currently in the process of epoxying the gear and going to reassemble. Will keep you posted on how the work goes.
