Nissan Cube Factory Service Manual is now available
Home of the Nissan Cube forum and CubeDriver.com
D3stro
A little post to let know which section of the FSM are:
FWD - Index
ACC - Accelerator Control System
ADP - Automatic Drive Positioner
AV - Audio, Visual & Navigation System
BCS - Body Control System
BR - Brake System
BRC - Brake Control System
BRM - Body Repair
CHG - Charging System
CL - Clutch
CO - Engine Cooling System
DEF - Defogger
DLK - Door & Lock
DLN - Driveline
EC - Engine Control System
EM - Engine Mechanical
EX - Exhaust System
EXL - Exterior Lighting System
EXT - Exterior
FAX - Front Axle
FL - Fuel System
FSU - Front Suspension
GI - General Information
GW - Glass & Window System
HA - Heater & Air Conditioning System
HAC - Heater & Air Conditioning Control System
HBB - Hybrid Battery System
HBR - Hybrid Brake System
HRN - Horn
INL - Interior Lighting System
INT - Interior
IP - Instrument Panel
LAN - LAN System
LU - Engine Lubrication System
MA - Maintenance
MIR - Mirrors
MWI - Meter, Warning Lamp & Indicator
PB - Parking Brake System
PCS - Power Control System
PG - Power Supply, Ground & Circuit Elements
PWC - Power Window Control System
PWO - Power Outlet
RAX - Rear Axle
RF - Roof
RSU - Rear Suspension
SB - Seat Belt
SBC - Seat Belt Control System
SCS - Suspension Control System
SE - Seat
SEC - Security Control System
SN - Sonar System
SR - SRS Airbag
SRC - SRS Airbag Control System
ST - Steering System
STC - Steering Control System
STR - Starting System
TM - Transaxle & Transmission
VTL - Ventilation System
WCS - Warning Chime System
WT - Road Wheels & Tires
WW - Wiper & Washer
^ Nice work. We plan on implementing that into the navigation page (if I ever get time to put it together)...
CBURKE
Car: 2012 Nissan Sentra SE-R Spec V!
Thank you!
mnb
please upload the factory service manual for nissan cube 2004, engine (cr14de)
need it badly
regards
Sfe80
Car: 2003 Nissan Cube BZ11
mnb wrote:please upload the factory service manual for nissan cube 2004, engine (cr14de)
need it badly
regards
Did you ever have any luck finding the manual? I've got a 2003 Cube and could really use it! Referencing a Nissan Micra service manual only gets you so far...
Let me check with our contacts... stay tuned.
roswell
Car: 2003 Cube3 (Cubic) in Japan with 135k km.
Please let us know. I just got an 03 cubic today, and it needs some love.
Return to “Cube Forum”
