This is what corp told me there dealership said. Now i have had the car since april and it just recently started smoing so can i still prove them wrong? and i have it logged in my computer when i did the oil changes and what not and it has no mods on it because of the fact the engine started messing up they are all still in the boxes brand newnametakennow wrote:Probably would have been better to add this to your previous thread...
Anyway, your engine started burning a significant amount of oil most likely BECAUSE the precat failed, not the other way around. Furthermore, as long as you can prove you kept up with maintenance and that any modifications you have (if you have any) did not create the oil burning issue that they claim caused the precat failure, it's still definitely their fault.
Is this direct from Nissan corporate or is this the dealer talking?
Please. What year is it, and how many miles?EL MAMITO USMC wrote:if you post some info on your car that would help and if it's still under warranty
^^ yea its a 03 spec 56k its been about 3 days since i have heard from them again. not having a car sucksnametakennow wrote:It's an '03 Spec with ~56k.
Other thread- zer...-san1
Fixed spelling of "their" in title, it was bugging me.
Thanks. I didn't want to say anything, but it was bugging me too.nametakennow wrote:Fixed spelling of "their" in title, it was bugging me.
I was on the phone with them when i made this thread i was kinda mad, and i wasn't thinking. Yes, I do have a fight but i am not giving up on it. I am still under mileage on the power train warrenty although yes the 5 years is up, i had a site that said a 12 month grace period is offered if ur under the mileage still but that could be false i will find the link and post it.Buzzman wrote:
As for the car, unless warranties are a lot longer in the U.S., this thing is past it's best before date. You've got a fight on your hands.Good luck.
OK, just read through the other thread. Should have read that first. Sorry.
(why 2 threads on the same issue, BTW?)
??? this doesn't make sence, and I agree there is no reason a 56k mile engine should be buring oil, something internally is wrong and must be addressed, but a disentigrating cat will go out the tail pipe, not into the engine, so the eingine can mess up a cat but I fail to see how a cat can mess up an engine, you need to find out wht it's buring oil, how is the oil pressure? have you done a copression test?nametakennow wrote:This isn't making a lot of sense. There's no reason burning oil should be acceptable, and, furthermore, it's a symptom of precat disintegration, not the other way around.
The exhaust valves are open during the intake cycle to act as an EGR without having an EGR tube. If the precat disintegrates, pieces of it can be sucked into the cylinders rather than harmlessly going out the back.evildky wrote:??? this doesn't make sence, and I agree there is no reason a 56k mile engine should be buring oil, something internally is wrong and must be addressed, but a disentigrating cat will go out the tail pipe, not into the engine, so the eingine can mess up a cat but I fail to see how a cat can mess up an engine, you need to find out wht it's buring oil, how is the oil pressure? have you done a copression test?
that just sounds like a bad idea, I would assume there si some sort of variable valve timing so it doesn't do this all the time right? otherwise it would be horribbly inefficient, you effective reduce the volumetric efficiency of an engine when doing this and that's no way to make powernametakennow wrote:
The QR25DE does have CVVT.evildky wrote:that just sounds like a bad idea, I would assume there si some sort of variable valve timing so it doesn't do this all the time right? otherwise it would be horribbly inefficient, you effective reduce the volumetric efficiency of an engine when doing this and that's no way to make power
it is inefficient, if a part of the intake cycle of the piston is wasted drawing burnt exhaust back in then less fresh air can be drawn in, this results in lower volumetric efficiency wich by definition is inefficientnismo4life11 wrote:its not bad or inefficient its just a way nissan found to have a less moving parts and less complicated way of dealing with unburnt exhaust fumes coming out of the motor (instead of having the whole EGR system). Plus its not like the valves are open all that long together its probably just milli seconds. Nissan engineers know what there doing for the most part. I guess they just dont know what materials to use for a cat. Glad i got the 2001 SE with the sr20!!
And go back to the days of carburetors, automatic chokes that never worked properly, plus points, condensers, distributor caps and such? No thanks.I'm an older fart too, and I don't miss that stuff at all.Not having to change spark plugs every 6 months or replacing ignition wires once a year is great. There are things that will go wrong with new technology too, but it's nothing like it used to be. Cars are so much better now.evildky wrote:
I guess I'm just getting to be an old fart that likes the good old days of engines with static cam timing and no cats
