Damn. I have to say in terms of engine work you took your path to where i was planning on taking mine. Awesome work
, meth should give you even better numbers.
The vq35 is a well built motor, it cant take TOO much boost though so its not the best either without spending money on internals. For example the 1.8T in my a4, stock is 170hp at the crank, and it can take up to 400 at the crank before you need to worry about changing things.
In terms of original power to aftermarket possible power without rebuilding, the 1.8 wins cause it has the most hp/tq gain without rebuild.
Your vq is making 425 chp, so overall more, but less of a hp/tq gain then the 1.8t, and your starting out with 2 extra cylinders1. and 1.7 extra liters.
425hp is impressive, how is the rebuilt trans holding up? No slippage or anything?
Here are the things id really want to see ( would make me dump the money on collecting parts for this quicker too probably LOL )
- Someone standing outside of the car and launch it
- Couple pull vids, 20-60 , 40-80 etc, i really want to see the midrange and top end improvement, also is your governor removed? Im interested in a 70-100mph pull too.
- 0-60mph time or video
You really have to take alot of pics, and all the info you can from your mechanic so that way for any followers (AKA me) knows what worked for you, and takes out the time of figuring out where to tap oil, etc etc and stuff like that.
