New Wheels... Question!
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
xtwoonamatchx
Car: 2007 Nissan Versa S
So, my friend is selling me his 18" rims for $350. They are 18" x 7" with a +45 offset. Im going to go with 205/40R18 tires cause that will leave no difference with the odometer and speedometer. I have no idea of what the offset should be so that is what my question really is.
They are RPM R-501 Black with the chrome lip
Thanks!
Promise Land
Car: 2011 Nissan Versa
2001 Chevy Suburban
1992 Ford Mustang
I think +45 is OK. Try checking what the typical fitment recommended by TireRack or a tire wholesaler. That will tell you if you're in the range.
blindsnyper
Car: 2007 versa
if they dont work you will only need about a 3mm spacer in the front (i know for a fact that +42 will work), the back should be fine.
Return to “Versa Technical Discussions”
