Yoda, the "super beetle" shocks I spoke of are the ones J30_Kidd used. Monroe 73948. They seemed like the most precise fit in his posts. My Monroe 73948 box came with a metal hat/spacer that was the exact thickness needed (in lei of the PVC pipe spacer). So I figured it would be a plug & play install... WRONG.
I attempted the install this afternoon with lackluster results. This metal hat/spacer made the strut body too tall so the big nut could not be screwed down
Okay, so I went with the PVC spacer method. Should've been smooth sailing from what I read here... but I could not find a way to evenly sand down the inside diameter of the pipe, so there is a little play side to side until the nut is tightened down on the strut body.
It's all back together, but is making a clunking noise when I drive. Any ideas??? I chose to delete the hose "bushing" that others placed right below the threads on the strut piston... I can't see that being it, as it all fit snug when bolted together. Kills me that I may have to disassemble all this & add that s*** bushing.
Seemed like an easy install online but WOW was I unprepared for the belly of this beast!!!
