Welcome to NICO!
One thing to note is varmints/rodents like to chew up knock sensor wires. When I performed my mid-life refresh a few years ago, I found the KS harness had been eaten for lunch with only one strand of wire still holding.
I've seen KS codes on other Nissans be thrown as "Ghost Codes" that accompany other codes from like O2 sensors. Once the other code is corrected the "Ghost Code" will then disappear.
Do you know if your injectors are Phase II or Phase I?
If you are looking to use your Q as a racer, you might be able to rule out the KS issue like the owner of this Q in this picture did by mounting the KS to the intake plenum.
Note I snapped this pic from a salvage yard Q that was on the way to the crusher. As IBM would say, results may be unpredictable.
