Hey Skyline/GTR commuinity. We have never posted here since we have not had a product for you guys, but now we do. It is called an ECU Patch Harness.
The ECU Patch Harness allows you to bridge between your oem (or Wiring Specialties) wiring harness and ECU. With this harness in place you can install accessories such as turbo timers, electric meters, SAFC's, and anything else that requires tapping into your wiring harness for a signal. The ECU patch harness eliminates the need to cut into your factory harness and allows you to wire up accessories outside of the car with ease. No more crouching in the foot well of your car, on your back, trying to connect wiring in a tight, dim lit environment.
Each and every Patch Harness uses OEM connectors/plugs and installs in seconds! You can quickly and easily take the patch harness out of the car to your accessories and then plug it back in.
People looking to sell their vehicles in stock form can enjoy selling a vehicle without having a hacked up wiring harness from where your electronics use to tap into.
Harnesses are available for all RB engines and the VR38!
You can learn about the product and compatibility on our website: http://wiringspecialties.com/ecupaha.html
