rhetoric wrote:Bought a 96 i30 (luxury -- leather) w/ 150K(?) miles and virtually no rust for $1800 from Cr**gslist. I really wanted a Saab, but this seemed like a good deal and I couldn't pass it up. I think of the Infiniti as "sensible shoes."
I was just looking for a third car for around town since the daughter is now commuting to college (she gets the 1990 Olds!). I'm not expecting this thing to go to Nome and back.
Car spent most of its life in Charlotte, so the rust isn't bad (a big issue in Rochester NY).
On the plus side? Quiet! Luxurious! Comfortable. Tight (tracks straight and true w/ NO vibration at speeds well over the legal limit!). Babe magnet (kidding). The previous owner just put $500.00 of new tires on it (didn't plan on selling). I, a person who has driven Fords, and Oldsmobiles and Chevettes, get to say, "I think I'll take the Infiniti."
On the down side? The odometer is broken. I have reason to trust the seller who estimated 150K. It's stuck at 105K. I have to put premium gas in it! No owner's manual. You really fall into the car. It sits LOW (small potatoes).
On the iffy side? The transmission shifts a bit hard when it's cold. Seems to soften up after the first time through the gears. I haven't changed the transmission fluid yet. The car surges EVER so slightly under acceleration. Fine at speed and the surge is barely noticable, but it's rhythmic and noticable. I need to check and see if it's reflected in the tach.
I'm running Chevron's fuel system cleaner right now and will then change the oil and tranny fluid. Overall, I'm pleased.
Any advice is welcome!
Welcome to NICO!
Congrats on the purchase. I would, first of all, look into getting a used cluster from a salvage yard; maybe one close to 150K mi? Second of all, you don't need a stinking owner's manual, even though they can be found on eBay for cheap. Here's the FSM (Factory Service Manual). You can't really go wrong by changing the fluids, especially the coolant given the fact that you're in NY. I would change the oil/filter, trans fluid/filter/pan gasket, thermostat (no gasket needed, use gray RTV) and coolant. Maybe look at the air filter and pull a spark plug or two. Also check out the gear bellows (rack and pinion boots) for possible leaking.
