This weekend I was able to get a few things done. In the trunk of my car when I picked it up was a second drivers side A-Pillar with an empty 2 gauge pod mounted to it.
I installed an old Autometer Boost gauge I had laying around and found that I am running at like 8.5 lbs of boost. I did some more looking at my engine compartment and followed up with some online research into the whole boost restricter and pill in the vacuum line. Take a look at this picture:
So the factory boost restricter has been deleted completely. So in theory as I understand it right now I should be running at waste gate boost pressure, right? Is that roughly 8 to 9 lbs of boost? I'm thinking when I am at the dyno on Friday I may go ahead and install a MBC and set it up for 13 lbs of boost. That should be a safe amount based on my research on the factory turbos.
I was also looking into my stereo system that sounded to be a little bit more than just a nice Pioneer aftermarket deck. So the deck is a Pioneer DEH P4000UB, the door and deck speakers are JL Components and there is a Clarion Pro Audio 600 Watt Sub pushing the door and deck speakers. While it sounded good it did not quite have the bass in it I was looking for so I added a West Coast Customs 1200 watt sub with a pair of their 12's in a ported box. All in all it sounds phenominal and I am in the process of using a dynamat like product on the trunk lid to get rid of the minor rattle I get from the bass. The Sub box is set up so I can easily pull it out for track days so it won't add weight and slide around.
I started on my shopping list of mods this is the list in the order that I plan to pick them up, I would like to build up to a 500-550 at the wheels HP. Since I haven't posted it in this thread yet here are the current stats for my car:
ENGINE
- R34 GTR long block with R32 cams / turbos and management with stock tune.
- New timing belt
- New N1 water pump
- New N1 oil pump (R34 motors come stock with the better crank and oil drive issue solved!)
- Mines style large intakes with K&N cone filters
- HKS aluminum intercooler piping.
- Turbo XS RFL blow off valve
- ACT heavy duty Clutch
- 3 to 4" catback exhaust
- Short throw shifter
BODY
- Full BeeR style R324 wide body kit
- Recent base and clear. Paint code Nissan super white 623
SUSPENSION
-Tein spring and shock combo made specifically for an R32 GTR. The car rides comfortably and handles very well.
-Rear Strut Bar (not sure what type)
My Shopping List:
Factor R34 wheels (18x9) on order now with Bridgeston Protenza 245/40/ZR18's
AEM Tru Boost (boost gauge and controller)
AEM Wideband O2 Gauge
AEM EGT Gauge
Haltech ECU with E85 sensor
Down Pipe (unsure on which one)
Upgraded Fuel Pump (Still researching which one to go with)
Fuel Injectors thinking 1000 CC (depend on final turbo choice)
TOMEI Headers and dump pipes
Turbos, I am leaning towards the The TOMEI Arms Turbine Kit - M7655 Or Garrett GT2860R-5
Upgraded Front Mount
I'm also going to be looking at some suspension and brake upgrades as well as some general under hood clean up and beautification. I may pick up a second set of valve covers, center cover, timing belt cover etc to get powder coated. I may also get sidetracked with some CF goodies for the body too as I love the look of a white car with CF accents.
Here is a pic of my previous build so you can see what I mean:
Well I think that is it for now. I'll post more and get some more current Pics of the Skyline soon!
Matt
