3Q Jay »
https://forums.nicoclub.com/3q-jay-u16163.html
Sun Mar 01, 2015 6:53 pm
I will guess that the door has been re-keyed and now doesn't match the ignition.
my '95 had the t-stat fail open (well it was just the sealing o-ring internal had split, but it was allowing coolant flow when cold.
to verify this, i would check the radiator flow when engine cold and see that there is some flow even when cold.
tough to rely on the panel gauge. it is not very sensitive.
also, just bear in mind that a gauge probe that is not immersed will read cold even when the engine is near meltdown.
best is to get your consult-1 dongle (yes, even though the '97 is OBD-II, there is still a consult-1 port).
or, get an OBD-ii tool that is more than a scan, but a diagnostic as well (o2 sensor real-time, fuel trims, other ecu functions.......)
