http://www.theretrofitsource.com/compon ... 48707.html
REVIEW:
I updated to these from Phillips Ultinon 85122WX - considered the finest D2S bulbs in the 6000k range. Mine were about 2 years old and began to lose their brightness. I wanted a more 'daylight' effect on the road so I switched to the Osram CBIs. I believe these are nearly the same cost as the Phillips. Osram CBI's are the ultimate in the 5000k range and are referred to as the "Rolls Royce" bulbs. They have a unique tint - not blue, not yellow, just pure daylight. These bulbs are truly amazing! They shine significantly farther than the Phillips. They cover what seems to be twice the width - on the motorway they cover 2-3 lanes on either side of my car! The road surface looks so close to daylight that I'm convinced night fatigue on long trips will not happen. I have 35w Osrams with 35w OEM ballasts.
My GoPro will be coming in this week and I will post a video.
Osram light@day LEDs : $219 /pair
http://www.motivemods.com/
currently backorderd - call them on (559)362-0194
REVIEW:
These DRLs have the newest technology - a homologated LED bar (instead of individual LEDs).
One clean bar of light across the unit. I'm quite pleased with this design. They work perfectly - auto ON when the engine starts, auto OFF about 20sec after the engine is switched off. These are larger then the Phillips DRLs they replaced. These also have chrome trim, making them more noticeable than my previous Phillips Daylight-8 DRLs which were quite thin, all black, and barely noticeable on a black bumper. I miss how the Phillips blended right into the bumper, but I love the new technology and the appearance of a single bar of light.
Fog Lamps: $40/ pair including bulbs
http://www.ebay.com/itm/Fog-Light-Lamp- ... 593wt_1194
REVIEW: These are actually made for the Nissan Sentra / Maxima. I read on the forum that they match our M's perfectly and they do! (The OEM part from my Infiniti dealer is $160 + installation for ONE side) These came with bulbs already installed but I wanted 3000k in my fogs so I didni't use them. Removing the lower grille wasn't as hard as I expected. You will need to pull rather hard to remove it though. Worst part was sliding a screwdriver into the small hole above the foglight to turn the inner clamp to release the outer end of the grille. It's bloody dark in there! REMEMBER to cover the surrounding area with two layers of painter's tape. As you slide the grille out, it WILL scratch the bumper. My tape had heavy scrapes but the bumper survived scratch free.
Fog Lights: $72/ pair
http://www.ebay.com/itm/PIAA-13511-PLAS ... 2893wt_956
REVIEW:
I am a firm believer that fog lights should be used ... well ... for fog. I can't work out why some peeps drive with their fogs on 24/7. Also, if you use white bulbs for fog, you will increase glare instead of increasing visibility. These are 2500k ... anything up to 3000k is ideal for increased visibility in fog or misty rain.
Caliper Covers: $200/ 2 front + 2 rear
http://calipercovers.com/vaf/product/li ... _model=179
http://calipercovers.com/faq/
REVIEW:
These are an easy install. They have a powder coated + clear coated finish that will not rust or fade. The engraving is deep and will last forever. This design is solid and heavy - different from the cheap glue-on covers. These actually guide the heat and brake dust out the top and back - keeping the brakes cooler and reducing brake dust on your wheels. They aren't available with the Infiniti logo, so I bought decals. These covers can be removed and replaced in about 2 minutes for brake jobs.
Caliper Decals: $6/ 2 front + 2 rear
http://www.ebay.com/itm/INFINITI-Brake- ... 1881wt_956
REVIEW: These are 'high heat' decals - very sturdy and will not fall off or wear off. They were designed specifcally for high heat surfaces like calipers. Since mine are on my caliper covers instead of the actual calipers, the heat is reduced so they will likely last a very very long time.
Brakemotive Rotors and brake pads: $189/ 4 rotors + 4 pads + optional hardware kit
Currently backorderd but available on Ebay soon - call them on:(877)-477-9320
REVIEW:
No need to say much about these by now. Everyone on the forum that uses them is quite happy with them. I noticed a huge difference in braking - very quiet, very very smooth, and they don't fade even when braking from high speeds. The braking force remains constant and smooth from the first touch of the brake pedal untill you stop.
Total bill for these mods: $911 + shipping for 2 items (all Ebay items shipped free)
