Sorry guys I was out of town.
XIS wrote:Thank you!
Very interesting and great results. Do you mind sharing how much $$ this ran you?
This ran me about $1300 (installed) vs the >$2300 (plus labor) of going with the Infiniti EX35 OEM application.
zarar wrote:I am curious myself how much this setup cost. I am currently using just a plug and play kit on my halogen lamps, visibility is not the best. Would love to do a proper retro fit.
See above.
I tried a PnP kit and even though at first the output was acceptable (mind you better than the halogen OEM) it got old fast.
EXceptional wrote:The last two Pictures are very impressive.
Thanks for sharing.
Thanks. The output is only getting better as the bulbs "burn in".
Supposedly these bulbs turn slightly whiter as they "set" into place.
They are 5K in color to begin with but I suspect they should burn into a 5600/5800K color which is a more rich white.
AZhitman wrote:WOW.
I really wish we had more detailed info on this, it would make an awesome DIY article!
I had this done at an auto retrofit lighting shop since I didn't have the patience nor did I want to "screw up" anything while using such expensive components.
Very soon I will grab additional photos specially lighting down onto a road.
