HA! Deal with DSM's for a decade, THEN talk about setting your car on fire!240slidekat wrote: im ready to set this car on fire.
no its a series 1 rb25 headCjmartz2k wrote:Umm, maybe not the lifters? It's not a Neo with solid lifters, is it?
noCarl H wrote:did you block off one of the oil feeds or put any restrictrors in it?
definately not injectors or rod knock because i bled the previous lifters and they were actually quiet for a minute and back to ticking again. thats when i replaced the lifters because i though it was the lifters.eh? wrote:rod/piston knock? Noisy injectors?
Rb25 rebuild curse strikes again!
yea they were fine when i installed it, i cant measure it now because my lifters are collapsed again. my guess is its not getting oil somehow.Darius wrote:Has the valve train been touched other than new lifters or cams?
Have you ever measured the valve lash to check that the buckets are riding on the cam?
im getting oil pressure, about 12.5-13 psi at idle with a n1 oil pump, there is literally oil in the head, ive replaced the lifters with new ones but it looks like they are collapse again (being able to squeeze it with hand, not stiff). still ticks.GTRs13 wrote:
Seriously, a little more info would help your diagnosis.
as soon as you start the car. no i have not driven it with the new lifters i had it running for 20 minutes to see if it goes away, i didnt want to drive it for the fear of messing up the new lifters. after that i removed the valve cover off and check the lifters with a screw driver and i was able to push them down easily.eh? wrote:When is this happening? Have you driven it and it still ticked?
You say that there is oil in the head, okay, that doesnt mean ALL the passages are open, a few might be blocked.240slidekat wrote:i can see that their is oil on the head where the cams are at, so would that elimate the blocked oil passage? as far as the oil level it is filled to the full mark on the dipstick. and the ticking is in both sides intake and exhaust.
i forgot what the oil pressure was at 3000rpm i think it was at 75psi warm i would have to double check.
yea, im using 15-50. ive tried different weigh but still the same results.eh? wrote:Did you buy those ebay lifters?Also what weight oil are you using?
Exactly right.Shocker wrote:If I recall correctly the oil passage for the lifters runs down the entire length of the head as one passage, its just cut out where the lifters sit.
correctShocker wrote:Has the head ever been hot tanked? This generally cleans out any possible clogs.
If none of your BRAND new lifters are filling with oil your passages are clogged somewhere. If I recall correctly the oil passage for the lifters runs down the entire length of the head as one passage, its just cut out where the lifters sit. I can look at my 25 head closer when I get home to verify.
You are running a 25 head with a 25 gasket on a 25 block right?
